Polk Audio CRS (Original) Crossover Modification Thread
VR3
VR3 Posts: 29,627
Tweeter Network -
Clarity Cap ESA
Mills MRC50 and Mundorf M Resist Supreme
Jantzen Inductors
Kimber Kable Internal Wiring
Midbass/SDA Network -
Clarity Cap ESA
Jantzen Inductors
Lexan substrate, point to point wiring
Aluminum terminal plate, kimber kable wiring harness
    EndersShadow Posts: 17,741
    Nice! 8 or 4 PR Trey?
    VR3 Posts: 29,627
    I believe it is the 4PR.
    I like it but I have to admit bringing four wires together to make a single connection is a little tedious... :smiley:
    VR3 Posts: 29,627
    Ah, the original SDA crossovers are so much fun :p. I use two small pieces of foam tape on the edges of the caps up top so you can still read the labels :)90gfd0bzehbn.jpg
  • drumminman
    drumminman Posts: 3,396
    Room is tight in those little cabinets, and that looks quite large. Interested to see how you fit and orient those boards.
    VR3 Posts: 29,627
    Designed it to attach in front of the terminal cut out. We are going to use stand offs and run the wiring through the gap.
    The unit is not as big as you think, it is 3.5" tall, 4" wide, 10" tall
    VR3 Posts: 29,627
  • Moose68Bash
    Moose68Bash Posts: 3,843
    Trey,
    You've done it again!
    Great looking work -- technology married with fine art! :)
    Phil
  • Faustin
    Faustin Posts: 1,151
    Beautiful work. If I didn't know better, I would be looking for the button to detonate it.lol
    VR3 Posts: 29,627
    Thank you guys! I appreciate the kind remarks!
    This was an interesting build, the older SDA speakers were so different than the models that followed... :pcdv51axsruzs.jpg
