SAE A202 Power Amp
josephtenzin
Hello all great and wise Polk fans.
Is the SAE A202 amp a common ground amp and safe to use with SDA 2As?
Many many thanks for all of your support. I just ordered my blade-blade cable from Polk.
Hi joseph, I was hoping someone would chime in who's owned one of the SAE amps. I wasn't sure if you've purchased one or just thinking about it. I believe you can use an ohm meter to check resistance to determine if the amp is common ground or non- common ground. I once looked at one of the A202s, but the more I read on them it sounded like the A201 amp was a better series. DYODD. {EDIT} Just noticed the question was already answered in other section,lol.
