Well, gonna have to get dentures and have some questions....
starkiller
Bad teeth practice and diabetes has taken its final swipe at my teeth and its full denture time
So, would like to know what other people have done to get use to them......what to eat at the start besides smoothies....best adhesive.....how to work with them at the beginning so I can actually talk halfway decently etc....you can pm me also in case you feel better doing it that way.
Thoughts and tips much appreciated!
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
not there yet, but when the day comes, I will choose implants over dentures.... They can usually do the entire upgrade in a single day now, and the cost is cheaper than an Abbott mod from VR3The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Implants would be nice but because of the diabetes I do not have enough bone left to ensure that they would work for any length of time...Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Once you get past the gagging there really no big deal. I use Fixodent powder, works best for me. Talking only sounds funny when your not wearing them. The temporary ones they give you to begin with kinda suck but once your gums heal and you get the permanent ones there no big deal.
nooshinjohn wrote: »not there yet, but when the day comes, I will choose implants over dentures.... They can usually do the entire upgrade in a single day now, and the cost is cheaper than an Abbott mod from VR3
Cheap ? Who's your Dentist...Dowey/Cheatem and How ?
I've had 2 implants so far, at a cost of over 3g's each. A whole set will cost new car kinda money.HT SYSTEM-
lsi 9's -
So true. And that is only if you have healthy gums and bone. If not it will cost a whole lot more, and most of it is NOT covered by insurance.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
It ain't so bad. I've had them for about 8 years now (bad teeth and no money to get the implants). Plates were the most cost effective solution. You'll get used to them pretty quick. If they make good castings, the upper plate should fit well enough that you won't need adhesive. I don't like the bottom plate, so I just don't wear the damn thing. The only thing I have to stay away from eating are things like nuts (shut it), and crunchy stuff. Take care to keep them clean (polident every morning) and whatever you do, don't drop 'em in the sink. I've broken mine like that.
Good luck, and remember to smile!
-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
Heck Cathy, Dental insurance covers jack anyway. I don't know what it is about dental insurance, but coverage sucks between even the best policies.
lsi 9's -
Yep, it sure doesn't cover much in the way $...our out of pocket is going to be over $6k...:(Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
I hear you on that. I still have all my upper teeth but after having a bad problem with the lower teeth I had to have them all pulled. Trouble stated in my teens. I can't tell you all the money I've spent in my life trying to save my teeth. I hate my denture and don't wear it. Unless I tell people I have no bottom teeth they have no idea. I have more trouble speaking with the d-a-n-m thing in than with it out.
Best of luck Starkiller that totally sucks.
Because I am The Pumpkinking
Although I do not have dentures, I do have type 1 Diabetes. Might I suggest getting your H1C as close to 5.3-5.8 as possible. That will help prevent further damage to your body (i.e. kidneys, rhetinas, blood vessels leading to amputations of toes/feet, legs) etc.). I have had type 1 diabetes for 31 years now. Trust me starkiller, I know it's a **** to control. Regardless, it needs to be done. Blood sugar control is done through testing, diet, excercise, and medication. Put the effort into control of your bloodsugar, there IS a payoff.
I have lost an upper molar from biting down too hard on a spoon during an extreme hypoglycemic episode and someone giving me honey on a spoon. The tooth literally shattered in my mouth. Other than that, after 31 years, my teeth are pretty healthy. my H1C's are consistantly 5.2-5.4 for the last 22 years. This makes the difference. It's a hell of a lot of work, but your body is much healthier as a result.
That said, I am sorry you have to get dentures and I wish you the best from here on out. Do the absolute best you can do with your bloodsugar starkiller.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Greg, I think you meant A1C."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Sure did Fred. Actually, I meant HA1C. (Hemoglobin A1C). Thanks for the correction.
Mine is Type 2 and I have worked on it so now its below 7.0 when is was above 12...Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Any recommended smoothie recipes??Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
starkiller wrote: »Mine is Type 2 and I have worked on it so now its below 7.0 when is was above 12...
That's a great number man! Hopefully your dentures turn out fine.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
I am glad you have gotten it down, but there is always room for improvement. I hope you understand my intent. I am not trying to stress you out, but to have you be as healthy as you can be.
Yeah I know
Got labs done the other day and its now 6.6 so getting there. Anyway, wish me luck as the procedure is tomorrow. Its sedation time and they have me monitored because of that and because of the fact I had to discontinue my Coumadin for a few days as a result of possible bleeding issues. Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC -
Let us know how it goes.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
Well, it went. Between shots and pills didn't feel a thing but by jove I sure do now
Have to sear them all the rest of the day and night and then go in tomorrow morning to the denture maker to get them adjusted. Can't even take them out out to brush
Still pretty woozy as this note took me a long time to write even. Anywaym thanks for all the good vibes...my wife and I really appreciated it!
Now folks go on out there and find me a reasonably priced tube amp for my Orca's!!
Glad your procedure went well, and it's done. Take care of yourself.
Take some ibuprofen for the pain and get lots of rest. Glad all went well.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Feel better!Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Well, today was drag as I went to the denture doc for some minor adjustments. Well, anything but minor as the pain that was involved taking them out and putting them back in was, well, rather incredible. Not only that but he thinks that a bone spur I have might need to be "filed" down or removed and that sure doesn't sound fun at all.Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
