Crossovers.....
Legendary70
in Speakers
Hi.
I have 2 TSI 400's, TSx center, 2 PSW 110's, 2 polk surrounds and 2 Onkyo rears. All running on a Sony str-dn1040. I need recommendations for the crossover on all my speakers. I have them all on small and I have the subs on 80, the fronts on 80, center on 80 or 100, and the the four surrounds on 80 i think. what should they be on?
Depending on how you have everything wired up, use 80 as your starting point and adjust to your taste from there. The crossover I take it is being set in the receiver ? If so, then the crossovers on the subs should be turned to their highest value.HT SYSTEM-
lsi 9's -
Wired up? yes crossover is being set in the AVR. Highest? 120? 160? thx
Educate me on why 80?
The THX standard is 80.
