Sub Grill HELP
Systems
Oke
does any one know how to make a grill.
In my case a 10" whit a special logo
Or a company thank can make it for me.
Can anyone help me.
Can anyone help me.
Testing
Testing
Testing
Testing
Testing
there's lots of places that have plain grilles of many sizes; get one and carefully paint it yourself (it would be way expensive to get a company to do it). i'd say paint it, let it dry, then punch out all the holes again with a big needle.
crotchfield has someIt's not good, very fundamentally simply not good. - geolemon
Ok.. well you CAN make one...
Take a corningware dinner plate, set it on a sheet of wax paper.
/\ -- get the right size of course
get some fiberglass materials... a small bondo kit will work well, dont forget the glass itself. Lay out and fiberglass onto the plate and resin it, as well as build it out to as strong as you willl need for your design. The final coat should be an epoxy type glass coating that can be sanded.. also a bondo avail thing.
Let this harden, then trim the edges to make it round, as well as grind and sand the front. Then copy your design to the front, drill pilot holes, and start cutting with a coping saw ond/or a jigsaw.. be careful. when you are done, sand off the burrs, round any point to a fine horn shape or whatever fits ya... then paint it.
For a 10" you can pick up an 8.5" plate for a buck or two.. remember the wax paper is to make the flat areas for the screws, so over-make the edgews, then cut to match the sub. I would powder the plate with something if i were you.. otherwise you may have to somehow snap the plate to get it off.
In general. Have fun!
-Jerry___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself. -
if u do that, make sure you've got enough room under it for full excursion - this is something people have been doing a lot with polk's grilles - banging the cone into the grille, that is.It's not good, very fundamentally simply not good. - geolemon
Good point neo... I guess one could use something to prop up the plate if needed.
okay... i don't entirely follow the description. is the idea to make a mold of the plate and then cut that?It's not good, very fundamentally simply not good. - geolemon
no, what you're doing is taking the plate to make the back of the grille, it's a support to hold the fiberglass up and that makes the clearance for your sub's xmax or travel. what you do on the top of the plate is the thing you will sand, grind etc to make your design... I'll make a how-to pic as soon as i get my pc reloaded with the software...
You still need help on this one?___________________________
nope, i'm good, thanxIt's not good, very fundamentally simply not good. - geolemon
Okey___________________________
