Placement, placement, placement.
Moving into a new apartment for a few months, but this might be the most ideal placement room I've ever been in with my rig. Plenty of room to get the speakers away from all walls, and let them sing on their own with no corner loading. Just a nice simple 2.0 system!
Also spinning some discs off of my Pioneer Elite DV47-Ai, I haven't cycled this in quite awhile and forgot what a sweet sounding CD player it is. I can't wait until I can unpack some of my SACD's to spin on it. I feel like this player has more depth than my FLAC'd Squeezebox, and a better soundstage. Although this could be due to placement also, I should have the computer over here and running tonight hopefully to do some A/B for myself.
Moral of the story, don't go out and buy speakers you can't properly place in your room. Placement is SO key, one of the first and best tweaks I ever learned in the hobby. Back to work and tunes, enjoy your Friday folks.
  • codyc1ark
    codyc1ark Posts: 2,539
    @ZLTFUL I can try to make the 28th, but my brothers birthday is the day before, pm me with details. I'll try.
    @DSkip I think too many people try and stuff the wrong speakers in the wrong room. Over focused on woofer size. Placement is the biggest factor, imho...
    EndersShadow Posts: 17,732
    edited March 2015
    codyc1ark wrote: »
    I'm coming to that realization myself. I'm thinking the RS-II's will just want more room than I can give them. The RTA's are ok close up against the wall... but honestly I may look at buying a set of good bookies that I can pull out into the room for critical listening and pair with a small (15-30 watt) tube amps, but don't need a ton of space.... and a set of pro studio monitors (KRK Rokit G5's) for nearfield computer listening which is what I do a large majority of.
    Since I have my old sub in the mix up there it should help me out on the low end.
    DSkip wrote: »
    Dan, there is a problem with that idea - good bookshelves with sand-filled stands are going to be heavier than a tower. If you're going to pull out into the room, then why limit yourself to bookshelves? Small towers would do the trick as well.
    Its not the weight at all thats the issue, its the placement. Its harder to adjust a tower up or down height wise, whereas you can adjust the placement of a bookie on a stand.
    But I wont rule them out entirely....
    I've heard good things about the KEF LS50's with regards to both nearfield and also critical listening so its one thats on my list.
    Or who knows, maybe I just go with Pro Studio Monitors meant for nearfield for now.
