Polk audio sda 1c
Wondering if any one have a set of interconnect cables for polk audio sda 1c, which require the pin and blade cord. I've been looking everywhere for theses. Willing to pay. Thanks
Best Answer
  • Easy Runnin
    Easy Runnin Posts: 501
    Answer ✓
    Here is the first cable I made. I've since upgraded to speakons
    HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
    Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
    2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
    Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
    BR - Yamaha CR800/Polk monitor 5
Answers
  • Easy Runnin
    I made my own. Do a search on making your own. You can buy a length of cooper at Home Depot that is the exact size you need for the pin, attached that to a lenght of cable and your good to go. it's pretty easy. the blade connection was only for support
  • voltz
    voltz Posts: 5,384
    Agree, you could make one or others could make one for you. welcome to the forum and do some reading in the Vintage part of this forum where others are always talking about their SDA 1C's and other SDA's...lots of good reading in there if you look deep enough!
  • bcfd44
    bcfd44 Posts: 2
    Thanks for your response
    F1nut Posts: 52,244
    Do away with the pin/blade stuff and replace with SpeakOn connections, far better quality.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited March 2015
    You can make one from these two items and use the wire left over for new standard speaker cables. Just break off or dremel the outer lugs leaving only the center pin.
    http://www.monoprice.com/Product?c_id=102&cp_id=10239&cs_id=1023901&p_id=2816&seq=1&format=2
    http://www.monoprice.com/Product?c_id=104&cp_id=10424&cs_id=1042404&p_id=6212&seq=1&format=2
