Anyone have access to bottom spacers for the LSi15's?
There are 4 plastic spacers between the base and the speaker on the LSi15. One of mine cracked and nobody including Polk stocks the part anymore. Anyone have one to sell?
Answers
    F1nut Posts: 50,735
    I'm not sure what those spacers look like. If they are not something found in a good hardware store or from one of the many online sources of such parts, do you know anyone with a 3D printer?
  • Unfortunately nobody seems to carry these and they are specific to Polk. I can ask on a 3D printer. Good thought.
  • deucekazoo
    deucekazoo Posts: 146
    Can you post a picture with dimensions. That would give us an idea how to help.
    Polk S10, S8, S4
    Polk RT8
    Polk Monitor 7s
    Working on getting SDAs
    EndersShadow Posts: 17,596
    I have 2 of them for my LSi 15's that I need to install at some point.....
    IIRC someone here, think it was @Lasareath had a 3D printer.....
    I'm not gonna part with mine as someday I will install them...
    @nooshinjohn used something from a hardware store that is PVC and looks quite cheap.... maybe he will weigh in here on what he used on them (I bought these off him) as a alternative. He never painted them (nor I have) as they are for the rear of the speaker and not that noticeable (dont think my wife has even noticed in 5+ years)
  • Thanks. I am using a cut down wine cork now. Not ideal but works.
  • deucekazoo
    I think I found a picture of what they look like, kind of. Try using a 1/2" or 3/4" PVC water pipe. Cut it down to size and paint it black.
    Polk S10, S8, S4
    Polk RT8
    Polk Monitor 7s
  • Thanks. I will give it a shot.
