NICE Rotel RA 1070 100w/ch integrated amp w phono
geppy1
FS Very nice top of the line Rotel RA 1070 integrated amp with manual and power cord. The RA 1070 puts out 100 watts per channel into 8 ohms and is a high current design with high dynamic headroom so low impedences are no problem. See the excellent review on the TNT site. New it was $1200.
The RA 1070 has 8 inputs including 2 tape loops and an excellent phono stage. It can drive two sets of speakers and headphones. Bass and treble are controlled by unique contour selector. It also has preamp out /main amp in jacks as well as triggers and can be run via computer. The 1070 has a very nice digtial display and the inputs can be renamed. The display can be turned off via the remote which I do not have but most universals run the RA 1070. The correct remote is the RR969 which is easy to find. The unit works perfectly and is in excellent condition.. There are a few very tiny scratches on the top of the left ear.
This is a great integrated amp for the money Asking $375. Thanks
I am in MN and shipping is no problem. PM for pictures
Category: INTEGRATED AMPLIFIERS
Model: RA-1070
Title: High current stereo integrated amplifier
Flexibility and convenience highlight the RA-1070. Substantial power (100 watts x 2) and a damping factor of 400 assure precise control of all but the most demanding loudspeakers. The high capacity power supply features an oversized Rotel made toroidal transformer and British-made BHC slit foil capacitors. Convenience isn't an afterthought either. A separate Record Out selector adds flexibility. In addition, you''ll find a 12 volt "trigger "output, A/B speaker switching, separate Listen/Record selectors for eight (8) line level inputs along with a built-in MM phono, full remote control capability, and an RS-232 data port, and discrete on/off remote control command codes. The RA-1070 is truly a very impressive performance package combining musicality and easy operation.
Model RA-1070
Watts/Channel
all channels driven,
unbridged, 8 ohm load
20 Hz - 20 kHz, 0.03% THD 2 x 100 watts
Total Harmonic Distortion
(20 Hz - 20 kHz) 0.03% THD
cont. rated power
one-half rated power
one watt per channel 0.03% max
0.03% max
0.03% max
Intermodulation Distortion
0.05% max
Damping Factor 400
Input Impedance/Sensitivity
Phono (MM)
Line level inputs -
1.2 mV / 68 kOhms
1.5 V / 33 kOhms
Input overload level
Phono (MM)
Line level inputs -
70mV
5V
Frequency Response
Phono input
Line Level Input -
20Hz - 20kHz +- 0.5dB
4Hz - 100kHz +- 3dB
Tone Control
Bass
Treble -
Signal to Noise Ratio (IHF A)
Phono (MM)
Line level input -
70dB
102dB
Power Consumption: 400 watts
Power Requirements: 115 volts, 60 Hz (U.S. version)
230 Volts, 50 Hz (European version)
Dimensions (W x H x D): 430 x 121 x 360 mm
16 15/16 x 4 3/4 x 14 3/16"
Weight (net): 10.3 kg, 22.7 lb
Model: RA-1070
Model RA-1070
Watts/Channel
cont. rated power
0.03% max
0.03% max
0.05% max
Damping Factor 400
Phono (MM)
Line level inputs -
1.2 mV / 68 kOhms
1.5 V / 33 kOhms
Phono (MM)
Line level inputs -
70mV
5V
Frequency Response
Phono input
Line Level Input -
4Hz - 100kHz +- 3dB
Tone Control
Bass
Treble -
Phono (MM)
Line level input -
70dB
102dB
