Harrison Ford Severely Injured...
nooshinjohn
In a plane crash on a golf course in Los Angeles.....
http://www.foxnews.com/entertainment/2015/03/05/harrison-ford-reportedly-injured-in-calif-plane-crash/
I saw this on line but didn't know it was Harrison. They say he's fair to moderate condition.
Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
I just heard the update... one lucky guy. It might have been worse if he flew from the forward cockpit.
The aircraft is a Ryan PT-22 Recruit. It looks like this bird is pretty messed up.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I heard he walked away w/ a bloody head and face.
Correct? -
I have no idea on that Red... These news reports always are made to sound more grim at first rather than optimistic.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
On the news they took him away on a gurney. That plane is 73 years old, Harrison is 72. I guess the plane meet its match and Harrison going to walk away!Anaheim Hills CA,
All things considered, that's not a bad crash landing.Political Correctness'.........defined
President of Club Polk -
Absolutely.
Must have been all that skill he picked up flying the Millennium Falcon... -
The last I heard was that the plane stalled @200 feet after banking to the left. It fell almost straight down after that, according to an eye-witness... He requested an immediate return to Santa Monica Airport after engine failure on takeoff.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Thats a great crash landing, my brother inlaws dad died this thanks giving while he was contracted for crop dusting in Yuma AZ. Planes man! super dangerous at night and miss my dear friend Mike like crazy.
nooshinjohn wrote: »The last I heard was that the plane stalled @200 feet after banking to the left. It fell almost straight down after that, according to an eye-witness... He requested an immediate return to Santa Monica Airport after engine failure on takeoff.
Sounds like he spun it in. One of the biggest mistakes pilots make is trying to return to the airport after an immediate engine failure on takeoff. If true then his landing and survival was luck, not skill.
Three 20 amp circuits. -
My thoughts too. Not much damage to the grass, and the landing gear is pancaked into the bottom of the fuselage. It also appears buckled behind the aft cockpit.
I just decided not to renew my membership in AOPA (Aircraft Owners and Pilot Association), and the last issue of their magazine I received was an article on this subject.Lumin X1 file player, Westminster Labs interconnect cable
Maybe his friend left his pet snake Reggie in the plane. Seriously, hope and pray he recovers okay.
Well he didn't pancake and found the best place to land he could
AFAIK. Seems he will be fine. Wa that a WWII trainer he was flying? -
Yes it was...rednedtugent wrote: »Well he didn't pancake and found the best place to land he could
AFAIK. Seems he will be fine. Was that a WWII trainer he was flying?
Appears he has a badly broken pelvis, some compression fractures in the lower spine and a broken ankle.
Not bad really considering his age. I'd hesitate to play armchair pilot though, the man has been flying for a good amount of time so I'm pretty sure he knows what he's doing up there.HT SYSTEM-
lsi 9's -
He's also a hypocrite and an arse....but I still hope he recovers well.HT SYSTEM-
lsi 9's -
It isn't the age...it's the mileage.....he will be ok!
agreed... I doubt he will be making the Kessel Run this year...
He is supposed to be making a new Blade Runner film. Assuming he can recover from this, and 72 is on the old side for fully recovering, I suspect any contracts will state no private airplane use. On the other hand, he has enough money and should retire.Lumin X1 file player, Westminster Labs interconnect cable
Wasn't really a crash. It was an emergency landing after engine failure on take off.
His engine failed at 350 feet of altitude and he contacted the tower declaring an engine out emergency. He made a turn to the left of 180 degrees and made a nearly perfect landing on the Penmar Golf Course. If he had been even 40 feet higher he would have been able to go the additional distance to the long stretch of perfectly smooth golf course and would not have made contact with the tree. Since he didn't he set the aircraft down on the best available stretch of ground. He walked away from the crash with only minor injuries. A cut face and arm are pretty minor when you consider the possible levels of post failure damage.
He did a damn good job of saving himself, the people and their property on the ground, and even the airframe.
The plane had just been fueled and was in better than new condition. There is speculation that the fuel truck delivered contaminated fuel. But only the full one year FAA accident investigation process will give the exact cause.
I live a mile and a half from the final resting point of his aircraft. Been around that airfield since I was five. And I am the loud obnoxious guy at the city council meetings whenever they discuss trying to close or cut operations at the airport.
My only question is "who was here first." Don't like aircraft? Then sell your house and move somewhere there are no airports. -
http://hollywoodlife.com/2015/03/06/harrison-ford-plane-crash-injuries-pelvis-ankle-head/
More than just cuts and bruises...
You like ten miles from me as the crow flies... you should drop by sometime. I will light the grill.
Yikes! He might make a full recovery but it's going to take a loooooong time for it to happen.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
