VTI Products From Doug!
voltz
voltz Posts: 5,384
I been after a VTI audio rack for awhile and Doug at Douglas Connection has started selling VTI products now, so I got a audio rack w/coasters to roll my setup between rooms and also pick up a amp stand from him. So just a heads up to anyone looking for one give Doug a shout!
Thanks again Doug for all your help and everything else you have done :)
  • hochpt21
    hochpt21 Posts: 5,423
    edited March 2015
    Thats an awesome setup there voltz!!!
    Post edited by hochpt21 on
  • [Deleted User]
    [Deleted User] Posts: 10,716
    Real Nice! I don't need wheels. Wife says keep it in the mancave!
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    That's awesome!
    gudnoyez Posts: 8,159
    Nice rack, nice set up.
  • teekay0007
    teekay0007 Posts: 2,289
    Sweet setup there, voltz! Very nice. B) Congratulations!
    voltz wrote: »
    That Doug of whom you speak is, of course, our very own helipilotdoug.
  • MrBuhl
    MrBuhl Posts: 2,419
    Nice Darryl! How are you liking that Pho8? Beautiful rig man!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • voltz
    voltz Posts: 5,384
    Thanks all!
    Hey Ed! The Vincent Pho8 is a lot better then my Graham slee in many ways except sound where they are equal. The Slee is too light and heavy IC's can almost pull it off the rack, the Vincent is a lot heaver as you know from yours, and the separate power supply over a transformer block is nice, and it matches my other gear and it can handle low or high M/C Cartridges & MM. I have use many in the past and its now my favorite of all of them.
    I have basically 3 setup I can use. 1= my Vincent pre/pro & phono amps. or my MC100b or I can use the Dared Sl2000a tube preamp I got from Paul with my Vincent amp. MY favorite is my Vincent setup but the other Two are great to switch over to now & then.
  • cfrizz
    cfrizz Posts: 13,415
    Looks great, congrats.
  • [Deleted User]
    "MY favorite is my Vincent setup but the other Two are great to switch over to now & then."
    Options are important in this business. :p
  • hochpt21
    I may need that Dared back before too long :wink:
  • MrBuhl
    MrBuhl Posts: 2,419
    Super happy you turned me on to the Pho8 Darryl. You've got envious options for sure. Someday I'll make a tube amp move. I keep eyeing that same Silk in the FM. But I am of course, on temporary moratorium! You're happy with it tho?
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • engtaz
    engtaz Posts: 7,669
    Doug is a class act.
    engtaz
  • voltz
    voltz Posts: 5,384
    Hey Paul it yours anytime you want it back :) I have really enjoyed using it and probably have put 100+ hours on it, I did get some Psvane 12AT7 T-series Mark II's and they sound awesome in the Dared. But I admit it is not getting used as much as it should be and maybe would get used more if someone else had it, as it is a super little preamp.
    You always get 1st dibs! plus I have the MC100b for tubes and my Vincent preamp and amp are a hybrid design have have tubes and SS.
    Ed...The Mc100b is a really nice integrated amp and many here use one, Faustin, Marvin, Mikeyb and several use them with their SDA's. Tubes have the good and bad and the price goes up when you have 10 tubes and you want to do some rolling LOL!
    unless you get one with some nice tubes as part of the deal! plus it is really heavy like 70lbs. but I do like have the option of changing between the 2 or 3 set-ups.
