5000 suroundbar/Radio Tuner
I am so impressed with the quality of sound from the TV since I aquired the soundbar that I would like to play a radio/tuner through the soundbar Am I correct in assuming that with a RCA adapter I can do this ?? I am a novice so not too technical please :)
Best Answer
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Answer ✓
    Hello,
    I'm glad you're enjoying your SurroundBar 5000. Yes, you can connect any high level device, such as a tuner, to the analogue input. You'll need a cable that has RCA type connections on one end and a stereo 3.5mm plug on the other. Then change the input on the bar and you should be fine.
    Cheers, Ken
Answers
