Center Channel Question
AsSiMiLaTeD
AsSiMiLaTeD Posts: 11,728
edited February 2004 in Speakers
I just bought the CSi30 to go along with the RTi150s up front, but am not really 'feeling' this center channel. I just don't think it's a great match, too small and not enough detail in the high end.
So I've been looking for the CSi40, can't find it anywhere, not even on Ebay. Does anyone have any ideas of where else to look? More importantly, will the CSi5 work in it's place? I know that's the equivalant of it, but am not sure about the tweeters in both and if I can use the 5 with my fronts instead.
Post edited by AsSiMiLaTeD on
  • dave shepard
    dave shepard Posts: 1,334
    I would say the 40 would be the best way to go but the new 5 will work also and I dought you'll notice a whole lot of diff. I would wait to see if the 40's come up on Ebay again there on there quite often.
    Dave
  • fgr41
    fgr41 Posts: 432
    Once again it kills me I had a 40 and could not get any buyers. I had it on ebay and only got one bid for 176.00. It cost me more than that from the store. It was in 9/10 condition, only goes to show timing is everything.
    Front
    Polk RT800i (BI-wired)
    Rear
    Polk RT600i
    Center
    Polk CS400i (BI-wired)
    Sub
    SVS 25-31PCi (22Hz tuning port)... it's SubHuman
    Receiver
    YAMAHA RX-V1400
    TV
    Mitsubishi WT-46807 HDTV
    HD receiver
    T i V o HR10-250
