Polk Audio RTi10 Base
Found an old pair of RTi-10's but they are missing the feet and spikes. Since the Polk badge plate is to low, the speakers can't stand without a proper base. I was thinking of ordering just the feet-without spikes-but I'm not sure if the feet are tall enough to make the speaker stand without the Polk badge hitting the floor. Do I need to buy spikes too, or just the feet? Thank you.
Answers
    Just the spikes, but I would check the holes first to make sure nothing is broke off in there.
  • polrbehr
    polrbehr Posts: 2,877
    edited February 2015
    Tony, don't you mean just the feet? I'm pretty sure you have to at least have those plastic outriggers (feet), the spikes screw into the feet if you are on carpeting.
    If you have solid floors then all you need are the feet, which are important as the height of these could make them prone to tipping over. Don't ask how I know that.
    Actually yes, my bad. :)
  • koosimre70
    Én így oldottam meg, a gyári láb cserét. /Hungary/
    Házimozi:
    Erősítő: Pioneer VSX-AX3 , Táp.káb:Furutech Fp 314 Ag
    Hangfalak: PolkAudio rti 10, PolkAudio csi a6, JBL lx-22 H.kábel: Eichmann Express 2
    Sub: JBL ES250 pw, Magnat Quantum 530a
    Blu-Ray: Pioneer BDP-430 3D , Van Den Hul Optocoupler MKII. HDMI:Kácsa 1.4
    DVD: Pioneer DV-868AV-i-S
    TV: LG 42LA690S 3D Led.
    Elosztó: Hivox Alces3 táp:Furutech Fp-314Ag
