Recommend Some Small Footprint Monitors
kevhed72
kevhed72 Posts: 5,247
I am rethinking my secondary system, which consists of a Rotel stereo receiver at this point.....space is huge issue constraint so I'm looking for small bookshelves which can sit on a lower profile stand. Any ideas....looking for something around 7" tall max....used in good shape is acceptable.
  • deronb1
    deronb1 Posts: 5,021
    The monitors are 7" tall, or the stands?
  • Conradicles
    Conradicles Posts: 6,437
    Focal
  • voltz
    voltz Posts: 5,384
    I look on AudioAdvisor and almost everything was over 8.6"
    how about a speaker you can maybe turn on it side? like in this pic of Arcam solo's
  • kevhed72
    Monitors around 7" tall.....the smallest I can find while it not sounding like crud. If I flip them on their side the width can only be 4.5 inches....which is not a lot.
  • kevhed72
    Those Arcams may just fit on their side...
    EndersShadow Posts: 17,765
    Audio Engine P5s may work
  • deronb1
    Orb Audio? I think most things in the size you are looking for are going to be around 100hz. No sub?
  • Erik Tracy
    Erik Tracy Posts: 4,673
    I was going to say KEF LS50's, but they are 11.9" H, although they are a concentric design speaker, you could turn them on their 'side' - only 7.9" W
  • george daniel
    Tyler acoustics mini monitors
  • Mikey081057
    Mikey081057 Posts: 7,127
    P4's they are but they are like 9" tall
    I have a pair in Bamboo in my office.. They are nice little speaks
    Garage | Polk Monitor 5B's
    F1nut Posts: 52,406
    I think those Polk TL3's or whatever they're called are small enough. Gonna need a sub though.
  • Mystery
    Mystery Posts: 2,546
    Energy classic take satellite speakers:
    Each satellite measures 6.9 by 4.1 by 4.1 inches (HWD) and weighs 2.9 pounds.
    It's part of 5.1 package but amazon and other sellers sell just the satellites.
    Or, old realistic minimus 7.
    DSkip wrote: »
    How about those carver ribbon bookies? Forget their name.
    Sunfire CRM-2's :smile:
  • RamZet
    RamZet Posts: 792
    On a book shelf you wont need a sub, they will match well with a Rotel.
    B&W M-1
    http://www.bowers-wilkins.com/Speakers/Theatre_Solutions/Mini_Theatre/M-1.html
    B&W CM9Classé Sigma
  • aprazer402
    aprazer402 Posts: 3,467
    You did not mention your budget. I have listened to these small Cambridge Minx Min 11/21 speakers and they are very good. http://www.cambridgeaudio.com/products/speakers/minx-min-11-21
    http://www.crutchfield.com/fg_37900_FFBrand|Cambridge Audio/Cambridge-Audio-Bookshelf-Speakers.html
