45 degree binding posts, up or down?
Easy Runnin
in Speakers
I'm upgrading the binding post cups on a pair of Pinnacle bookshelf speakers. I'm removing a spring loaded set and going with the ones that accept banana plug. The cups I bought have the posts set at a 45 degree angle. Do I point them up or down? If I point them up, it appears to put additional strain on the speaker wire. If I point them down the plugs might not seat as well. I'm using 14gauge wire. What do you think?
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
Up.
