How is Netflix?
Being an Amazon Prime member for 3+ years, I'm getting REALLY tired of the direction they've taken.
Commercials, on Prime videos?
And now, you can't download content that you paid for, to your pc.
So...I'm looking for feedback from Netflix users, because I can't 'see' anything on their website.
How does it operate?
Do you get to keep the content you buy?
How much is it a month/ year?
As always, any feedback is appreciated.
  • rooftop59
    rooftop59 Posts: 8,121
    The website gives the basics. You are Renting everything, and buying nothing. It's a steaming service. I have prime mainly for shipping but use the streaming increasingly often (and have never seen a commercial???) but also have Netflix, for kids as much as anything. I think both offer a great value for the coin.
    Game Room 5.1.4:
    Bedroom 2.1
    EndersShadow Posts: 17,687
    obieone wrote: »
    Its a combination of a couple of things:
    1. Streaming only - you have access to anything in the library to watch as many times as you want unless they pull it from the library (for contract issues with the distributor)
    2. DVD/Blu-Ray only - you setup a plan with 1/2/3 DVD/Blu-rays out at a time. You put in a list of movies you want to see, and they send you what they can from your list. If the movie is part of a series they attempt to send you disc 1, then 2, then 3, but might not do it back to back to back.
    3. Combination of 2 & 3
    obieone wrote: »
    You never really "buy" the content, your always just renting access to their library. In theory you could illegall rip copies of the movies you get on disc for your library but I'd recommend against that
    obieone wrote: »
    Cost is dependent upon which plan you build for yourself. They are month to month and you can add/remove features at will
    Hope that helps. Here is what I do.
    I will watch a movie on Netflix/On-Demand, etc. If its a one and done, then I dont worry about it. If I think I'd watch it again then normally I just purchase it as the Netflix library fluxuates in regards to whats on there.
    Additionally anything you watch on the Streaming is compressed and limited to Dolby 5.1. Is that a MASSIVE dealbreaker, not really, I dont know of a company providing lossless audio soundtracks, but worth mentioning. The video is to some extent also compressed, but I've never had an issue with noticing the difference.
  • boston1450
    boston1450 Posts: 7,758
    edited February 2015
    We pay 8.00 a month for Netflix & 49.00 a month for our internet. Thats it. Havent had cable tv since 2003 YEAH :smile: love Netflix. Do research on what they offer to stream. Im not fussy on tv shows/movies from Netflix. That may be different with you
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • I have no complaints with Netflix streaming. The device used makes a big difference. The Ps3 does a great job as well as my bdp-s5100 and fire tv. All does Dolby digital plus 5.1 (bitstream) and can stream higher resolution HD depending on internet speed. Picture and sound quality are really good from these devices, not lossless audio but at least as good as DVD.However the Netflix app in my other (cheap) Sony bluray player and roku stick only does stereo via pcm And picture quality leaves something to be desired.
  • obieone
    obieone Posts: 5,077
    The way it worked with Amazon, up until 1/1/15, was if you bought digital content you could DL it to an app on the pc. Now anything you buy, is on their 'cloud' which I'm not a fan of, because, the player on the app is better, and, If internet goes out, I can watch it on my pc. It doesn't happen often, but....
    Thanks for all the feedback.
    Couple of more questions:
    What is the selection like? Can I stream TBBT. or Boardwalk Empire, etc?
    Or is it only movies?
  • Jimbo18
    Jimbo18 Posts: 2,348
    obieone, there are tons of TV shows available on Netflix. The selection is very good, but usually it's at least a year behind on anything currently airing. Amazon, if they carry the same show, tends to get the latest season a month or more ahead of Netflix, but their selection isn't as large as Netflix.
    However, Amazon has a much bigger selection of HBO shows, and I think I read that it's going to add even more of them. We have both services, no cable, and I prefer Netflix overall.
    The Netflix website gives you a pretty good idea of what's available. We have the 4 screen package for about $12/month, so up to 4 different devices can be streaming at the same time. Without cable, we use Netflix a lot. I probably watch it 10 to 1 over Amazon.
  • Sherardp
    Sherardp Posts: 8,038
    Not bad actually. I use it for traveling most of the time. Streams over the ipad, connected to the hotels tv via HDMI. Good content, worth the $12.00.
  • Irrenhaus
    Irrenhaus Posts: 1,098
    I have Netflix and like it. Works great on my laptop when I am traveling and in the house I use it via the Roku 3.
    They offer a one month free trial.
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • pongshi
    pongshi Posts: 376
    You can't beat what you get for the price. On my BLue Ray my netflix never seems to buffer, but on my laptop running Netflix, it seems to buffer a lot even though I have a strong wi-fi signal. Anyway, well worth 8 bucks a month.
    Living Room
    Parasound Model 2250v2 amplifier
    Parasound P5 preamp
    Turntable 1 - Technics SL-1210Mk2 turntable with Shure V-15 Type III cartridge
    Turntable 2 - Dual 1229 turntable, Dual AS-12 45 RPM stacker, Shure V-15 Type III cartridge
    Schiit Mani Phono Preamp for Turntable 2
    Oppo UDP-205 CD/SACD USB and FLAC duties
    Technics RS-1500US reel to reel
    Polk SDA SRS (2nd Gen) fully modded
  • codyc1ark
    codyc1ark Posts: 2,533
    I use Netflix, Prime, HBO go. I find having all three is a great combo, and gets me most everything I want. One of the things people miss the most is that if you have a cable provider log-in (I use a mediacom one) With the log in I can stream ESPN (live), Comedy Central and NBC. Now you just have to convince a friend or family member who doesnt use their online cable to stream and bingo, you've cut the cord and retained ESPN, just grab the networks you can off OTA and you are set.
