Is it worth it to use dynamat and hurricane nuts on a ported speaker?
Recapping a pair of pinnacle PN6+s. I guess dynamiting makes sense but should I bother with the hurricane nuts?
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
    F1nut Posts: 51,700
    IMO, absolutely.
  • teekay0007
    teekay0007 Posts: 2,289
    No! :o Dynamiting them will certainly blow them to bits, making them worthless and someone might get hurt in the process.
    Using Dynamat Xtreme on them is a given though.
    The hurricane nuts would also be a good idea as it would make the driver baskets and the baffle operate as one.
  • polrbehr
    polrbehr Posts: 2,842
    Ha, nice pickup there. Although that damn autocorrect is probably to blame.
  • drumminman
    drumminman Posts: 3,396
    teekay0007 wrote: »
    What he said. Better coupling the drivers to the front baffle would have sonic benefits. The dynamat would help if the driver baskets are stamped steel. If they are cast, not as much.
  • Internal pressures are higher (at the tuning frequency) in a ported enclosure than in a sealed enclosure. Passive radiator systems are essentially ported enclosures. basically the answer is yes: it would be even more important than in a sealed enclosure due to the increased pressures.
    treitz3 Posts: 19,958
    IMO, absolutely. Just be sure to not over dampen or the results will be more negative than positive.
