Tweak for RTA 11TL or 15TL owners
F1nut
F1nut Posts: 52,244
edited February 2004 in Speakers
Any of you that own either of these speakers should pop out the PR's and look inside at the bottom corners for loose or missing sealing glue. Any open cracks will affect the bass response as the cabinet needs to be as air tight as possible. I found that I had some loose/missing glue, so I sealed the areas with clear silicone, you might want to do the same.
Post edited by F1nut on
  • HBombToo
    HBombToo Posts: 5,256
    I have just bought a pair of 15's and after a good listen I'll comply. Come ta think of it... my 8T's will also be inspected also. Thanks for the advice F1.
    I need some working 11's? no ebay stuff cause I can't see it when I'm really surfen. The office that is.
    HTwin:D
    ***WAREMTAE***
    F1nut Posts: 52,244
    Henry is right, this would apply to the 8T's also. Thanks for bringing that up.
  • dorokusai
    dorokusai Posts: 25,627
    Wouldn't it basically apply to any old speaker, brain surgeons? I think that it would be silly not to open up an older speaker and at least look around.....you might find a body part....or gold tooth.
  • Tour2ma
    Tour2ma Posts: 10,177
    ... or part of Jimmy Hoffa.
    Jesse,
    Someone leave some 11's on your doorstep?
    More later,
    Tour...
    Vox Copuli
    F1nut Posts: 52,244
    Well Mark, I'm not talking about any old speaker, am I? The construction of the RTA cabinet seems to lend itself to this problem, that's why I felt others might be interested. I've looked inside the SDA's and a few other speakers, but saw no such problem. Now, just because you're my buddy I'm going to do you a favor while I have the silicone out. I'm going to caulk the living **** out of those DQ-10's for you. No need to thank me, I mean that's what friends are for right!?!
    Tour, some 15TL's showed up one day. I've got no idea what I'm going to do with them, but I've got to spruce them up some while they reside with me. :D
  • hotwheelman
    hotwheelman Posts: 1,300
    Found that problem in mine when I first got them. Also found a another problem on the front inside right of one.Kept hearing a hard rattle and found there was no glue in the joint from top to bottom of the cabinet, I glued the joint and put a clamp on from the outside until the glue could set. Now I have no rattle, I will reinspect mine as I cannot remember if looked in that location or not. Thanks for the info jesse.
    "Its worked so far but we're not out yet."
    "Hey big man let me hold a dollar"
  • dorokusai
    HWM - Stu was probably directly responsible for that problem....we should yell at him about that :D
    FU1Nut - Hey you leave my goods alone....you should be happy something non-Polk is in your house :D
    I think anything with internal baffles, would benefit from a peek as you have suggested. Excellent suggestion....fantastic...dont touch the speakers.....outstanding...unreal.....stay away....tremendous.....what speakers?
