SDA Passives
Any of the SDA's use a 15" passive driver? If so whats the dimension.... thinking I might able to use one of Larry's rings to get my driver mounted in my sub box.
  • drumminman
    drumminman Posts: 3,396
    My 2.3TL's use a 15" PR. Not at home so can't give you the the dimensions. Go with H-nuts if Larry's Rings don't fit.
    F1nut Posts: 50,753
    Using the 15" template ring the OD is 15.25". The ID is 14.25". Center hole to center hole is 14.75"
    EndersShadow Posts: 17,596
    edited February 2015
    So would it work with my driver? It looks like it should with no problem...
    Anyone have Larrys contact info by any chance?
    F1nut Posts: 50,753
    The measurements look spot on. Have you tried PM'ing Larry?
    F1nut Posts: 50,753
    Forgot, the only issue is the location of the mounting holes. The center to center measurement between the holes is 5 5/8".
    Yup I shot him a message but don't know how often he's on.
    Maybe he will see this
    @Toolfan66
    Yeah I don't see that measurement on the diagram so I'm not sure if the driver works w that.
    Got ahold of Larry. All is good.
