How to repair ic's that have a frayed jacket
I have a pair of Shunyata Cobra's and at the ends the jacket over the wire is frayed. It does not look like you can unscrew them so my question is how can it be fixed. When these hang from the back of my rack the weight of the cable puts a horrible almost 90 bend and that's gotta be hard on them.
  • BlueFox
    BlueFox Posts: 15,250
    Check with their customer service.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    Yep I could but its such a hassle and was looking for a quick fix, it doesnt look like they can be unscrewed to do anything about it.
  • Wardsweb
    Wardsweb Posts: 942
    Again pictures would help but have you thought about heat shrink over the fray and a few inches on either side?
  • polkfarmboy
    I have but although it could fix it I dont think I would like the look of it as it would be messy. I will charge the camera up and snap a pic later.
  • polkfarmboy
    No that actually looks like you a very nice pro job you did on those. The Cobras have a diff material on them otherwise I would be all for that.nd67crlyi0ls.jpg
    The cobras have frayed on my ic's and on the stock pic my cables have all the material hanging out them and just flops and hangs like a wet noodle.
  • drumminman
    drumminman Posts: 3,396
    Heat shrink would work on that material. Get the kind that has a 3:1 shrink ratio so it'll be snug.
  • Wardsweb
    Wardsweb Posts: 942
    Your only other option is to reinstall that connector, stretching the covering in the process to better fit in the housing. If it won't stretch, you will need to shorten the cable about half an inch. This does require some soldering.
  • BlueFox
    Again, check with customer service. They might fix them for free.
    cservice@shunyata.com
  • polkfarmboy
    But then I have to pay for shipping and wait etc. I think I am just gona get rid of them and be done as its a big nightmare.
  • polkfarmboy
    Oops where are my manners, I wana say thanks guys for chiming in with the help.
  • Wardsweb
    Wardsweb Posts: 942
    edited January 2015
    No reason to get rid of them. They are nice cables. They just need some TLC. The factory is an option or if you care to send them to me, I could give you options of types of repair, take of it and return them to you for free. If you're located anywhere between San Antonio and Dallas, I am driving up to Dskip's outside Denton on Saturday.
    Post edited by Wardsweb on
  • codyc1ark
    codyc1ark Posts: 2,539
    DSkip wrote: »
    Put a pair of skinny jeans on them.
    I LOLed. Nice job.
    F1nut Posts: 52,154
    Kevin, quit being difficult......geesh
    Unscrew the outer shell, pull the techflex up, slip a piece of heat shrink over it, apply heat, screw the shell back on.
  • polkfarmboy
    Lol, that was what I was hoping to do but I just cannot unscrew it for the life of me. If I can unscrew it then that would be ideal as the techflex would be concealed and provide support.
    F1nut Posts: 52,154
    Might be reverse threads.....call Shunyata.
    nooshinjohn Posts: 26,064
    With his luck, I would either buy new ones or send them in for repair. Either that or video the power-up of his gear for our enjoyment when the fire department shows up.
    Can't you zip tie them to something to take the weight off ?
    pitdogg2 Posts: 27,559
    drumminman wrote: »
    and maybe have an adhesive on the inside to help glue it.
  • polkfarmboy
    Shyit am like smashed out ma titz and trying to read threads, am gona call john lol
  • BlueFox
    LOL. Reading is easy, typing is the hard part.
  • ken brydson
    ken brydson Posts: 9,058
    I call bull$hit...
