Best universal RF under 150
EndersShadow
in Electronics
Title says it all. Open to used options but must be easy to program and use like the Harmony One it will replace.
Suggest away
Suggest away
Nothing but the angles are off for some of my devices so it won't control them well.
And there is no way to reposition them.
Plus in our bedroom our new furniture puts the bed directly in the way of the remote working."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I like the old URC MX-850, but it's not necessarily the best nor easy to program and you gotta get a copy of the software. I know a guy who knows a guy who knows a guy who could probably help. what were we talking about again?
Also. doesn't necessarily have access to the latest codes so you'd have to be okay with learning in some from your original remotes for the newest devices, but that's easy. you can also get an IR/RF extender for these things so that you can make your non-RF devices work with RF. I was about to go for the Harmony, but then I got the C2 and it came with the MX-700, and I kinda got into customizing the program and found that I really enjoyed it. I truely does replace all my remotes. I just removed the batteries from all of them, gave them a wipe, and put them in ziploc bags and packed away. I keep the cable + tv remotes out just in case, but I haven't used them in months.
you can find a nice MX-850 for around $70 or so on Ebay, less if you're willing to be patient or accept lesser quality condition. if you're cleanliness conscious as I am, they're pretty easy to disassemble and clean, and older ones seem to benefit nicely from the tune-up. just something else to consider if you're looking for something to tinker with.
URC MX-850 Product Page - http://bit.ly/1BqdlB9
Google Search for images of the MX-850 - http://bit.ly/1BqdcO8I disabled signatures. -
Enders, would something like this solve your problem? rakuten.com/prod/logitech-harmony-rf-wireless-extender-logitech-harmony-rf-wireless/203474219.html?listingId=368132346&sclid=pla_google_4SurPlusCityStore&adid=29963&gclid=CJbPp5-RusMCFRMkgQodYkMADw#
I had the URC MX series and can tell you I went back to a harmony within 3 days. The URC is a great remote but required a ton of set-up and learning commands. The ease of setup / operation and functionality of the harmony one is one of the best values in its price point especially used. Just trying to see if it would be possible to keep your Harmony One with an RF extender which will allow you to operate equipment even without line of sight.Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
Might. Think that only works with the 900 for some reason I can't remember. I'd still need blisters for my devices but that's meh cost wise"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Hey Ender I know the logitech harmony ultimate is over your budget. But they come up on the flea for half price and its one hell of a remote. Plus you are already use to the brand,
Cheers
Roger
