Amp ouput
footwedge
in Electronics
I recently added a used B&K 200.2 to my line up and noticed this past Friday the right channel is not as loud as the left channel. I have yet to recalibrated the system after adding the amp but this noticeable sound difference just recently occurred. Last night I replaced the LSI7's with the LSIM 703 and the volume difference is still present.
I plan to recalibrate tomorrow and if the volume difference is still noticeable, I plan to bypass the amp and connect the left and right channels to the SC27. If the volume difference disappears then I would have to think the right channel is going bad.
Questions:
1. Is it possible for an amp channel to gradually go bad?
2. I assume an electronic repair shop, who is an authorized pioneer repair center, could easily check the output of each channel and repair if needed?
3. I guess there could be an issue with the right channel pre-out on the SC27 or a bad ic?
4. is there anything else that could cause this issue?
Questions:
Maybe it's your ears...not kidding, I have better hearing in my left. After I calibrate I bump the right channel up one db and I sit about a foot off center to the right....then it's all good....headphones aggravate me though
Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant -
Manually set speaker levels both to 0. Make sure your listening position is of equal distance too. It is possible the amp may need some updating. Play something in stereo mode. Also make sure one side isn't over dampened by curtains or some other obstruction. You can always adjust the gain in the receiver to compensate, but that won't solve the issue if the amp needs some repairs.
Also swap speakers to make sure it isn't the speaker and double check the connections.HT SYSTEM-
lsi 9's -
jeremymarcinko wrote: »Maybe it's your ears...not kidding, I have better hearing in my left. After I calibrate I bump the right channel up one db and I sit about a foot off center to the right....then it's all good....headphones aggravate me though
It must be the DW ears also because when she walked in the room she put her ear to the right channel to see if it was outputting any sound. -
Also check if you hit the balanced connector on back the B&K which would drop the output considerably...
My tech did that initially on my 5 channel and was VERY confused lol"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
What Dan means is....check all the dumb arse mistakes one can make first, because we've all done it at one time or another.HT SYSTEM-
lsi 9's -
I will but before I changed the speakers everything was fine until last Friday when I noticed the volume difference. Never came close to touching anything on the back of the amp nor avr.
I failed to mention in my op that when I first noticed this no volume was coming out of the right channel. I then shut everything down and restarted. Then I had volume out of the right channel just a lot lower than the left channel. You have to get close to hear the sound -
If it was a tube amp I'd say re bias it, I had the same problem with my Mc100b tube amp and I checked the bias and 2 power tubes where way low and when set correctly the sound was back to normal. but your B&K is SS.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Seems to me you have some bad equipment then.
Recalibration has resolved the issue and did find that I had the ic's crossed.
Along this line, does anyone know of a CD that will generate equal strength signals from each channel, but separately? I have yet to find a test CD that will do that simple task. I want to use the SPL meter and see if the setup is balanced. Since my left speaker is three feet from the wall, while the right opens into the dining room, I expect the left to sound louder, but it does seem balanced now. However, I would like some data to verify that.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Yes, but I'm not that curious.
If there is any difference it is only a DB or so, but it would be nice to know, and tweak the appropriate channel gain.Lumin X1 file player, Westminster Labs interconnect cable
Would the static between radio stations and your balance control do the trick?HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5 -
LOL! This is why we tell everyone to double check everything before panicking! Glad you found and solved the problem.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Yes. But it's getting more and more difficult due to recent additions to move this cabinet away from the wall to access the rear panels. New I should've put this cabinet on wheels. Getting old beats the alternative.
Spoke to soon.
To clarify my statement about crossed ic's, I should have stated that avr pre-out R >amp channel 1 > left speaker and avr pre-out L > amp channel 2 > right speaker. In this scenario the left speaker produced much volume than the right to the point when seated at the listening position a mono sound was heard even though there was some volume from the right speaker that could only be heard from 2-3' feet away.
After correcting the cabling (avr pre-out R >amp channel 1 >right speaker and avr pre-out L > amp channel 2 > left speaker) and recalibrating, now the right speaker has much more volume than the left speaker, mono sound, but sound is emitting from the left speaker. Calibration shows L & R channel at +2.5db and +3.5db respectfully. Which seems to make sense since my seated position is 2.5' left of center.
With the current wire configuration, I activated and deactivated the xlr connection alternating between the left and right channels. When channel 2 xlr was activated I could barely tell a difference in the total sound output; however, when I activated channel 1 xlr the total sound output was noticeably reduced. So it's obvious that amp channel 2 is producing much less volume than channel 1.
The question is why or is this possible?
Can an amp channel gradually weaken or is it all or nothing?
I have quadruple checked all connections, cabling and the amp does not have gain control.
I plan to bypass the amp tomorrow connecting the L and R speakers directly to the avr speaker terminals to see if I get this same volume differential.
Not sure there's anything else I can check.
Make sure that nothing is sitting on or pressing on your speaker wire. I thought one of my speakers was going bad because it was a lot quieter than the other. Then after checking all connections I noticed that my speaker wire was trapped under the base of it's speaker stand, I moved it out from under and tada! I had full sound again.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
After connecting directly to the avr, the volume is corrected.
Before this issue began, my normal listening volume for music was between -25 - 20db. During this issue, I could go as low as -15-10db and the volume would not be unbearable when before it would've been. -
Cfrizz,
All connections have been checked.
Unless I missed something, all things point to channel 2 on the amp. I assume any qualified electronic shop should be able to confirm and repair this amp. There's very few to choose from locally. The one I plan to take it to is actually a certified pioneer repair center that recently fixed my sc 27 after being hit by lighting. I plan to contact ATI tomorrow for the schematic. -
Been rethinking this deduction and think I need to eliminate any issues with the ic's because they have been reconnected.
About to give up.
So today when I get home I put the amp back in service and believe it or not the volume is balanced. I grin thinking maybe it was a cabling error and because my sound is back. Then 9.5 songs into the "Alison Krauss + Union Station Live" cd, the left speaker (amp channel 2) disappears not completely but would estimate the output was reduced by 70%. The output lowered to a point were I had to get up I put my ear to the speaker to make sure it was outputting sound.
Any more ideas or suggestions on what could be the problem will be very much appreciated. -
Did you try different ICs? Did you try switching the ICs on the pre and amp?HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
I only have one set of ic's. I had planned on switching the L&R ic's to see if the volume differential would show up in the right speaker but once I brought the amp back into the mix and I was getting balanced volume from the speakers, I thought all was good. And, it was for 9.5 songs. I was too pi$$ed to try anything else.
Get another set of IC's before taking the amp in for repairs. You have to know if it's a cable problem first.HT SYSTEM-
lsi 9's -
Since the left channel seems to be the problem, if I switch my current ic's and the issue is still with channel 2 (LT), then would this not eliminate an ic issue? But possibly point at the amp or even the preout jack?
I had the same problem with a belles amp I had,it would play perfect for about 10 minutes then the right channel would drop.It ended up being the preamp output causing the isssue.2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
I've had issues with my sub dropping on occasions and would have to wiggle the cable at the preout jack to get it to come back. I've even turned the sub cable around and the issue still exists. So either the sub cable is bad at both ends or it's the sub preout jack.
I have no clue what it looks like on the inside or how the preout panel is designed but the sub preout is adjacent to the front l&r preouts! Could this be a clue? -
On my preamp it was the right channel throughout the whole pre,aux,cd etc.They all did the exact same thing.2 Channel
Oppo 103
Pangea PC
my only other device is my oppo connected via HDMI.
Sorry, just saw this thread.
Damn, footwedge I had absolutely zero issues with this amp.
Do you have any other pre's that you can try it with?2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
Try direct from Oppo. Variable volume set to lowest before powering up amp.Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
