Absolute Sound - CES high-end cables, power conditioners, and tweaks
I am a big, big fan of the audio improvements that clean power, good cables, and vibration elimination will produce when used with decent gear. I refer to it as the foundaton for your stereo.
This lists some of the new stuff at CES this year.
http://www.theabsolutesound.com/articles/ces-2015-high-performance-cables-power-products-and-system-tweaks/?utm_campaign=Newsletter&utm_medium=email&utm_source=email-335
  • BlueFox
    BlueFox Posts: 15,250
    Yes, in my HT. My two-channel in living room is treated via furniture, carpet, and physical layout. It works quite well. Just last weekend, I removed the Auralex Acoustic foam I had installed on the wall behind the speakers. It helped with the Aerial Acoustics 7Ts, but appears detrimental with the Magico S5s. I also swapped out my listening chair from a recliner that put my ears slightly below the tweeter to a chair that put my ears slightly above the tweeter. This made a big difference in opening up the sound, and appeared to be a bit louder, and clearer. I will do some more experimenting this Friday and Saturday night with rearranging some furniture.
  • mrbiron
    mrbiron Posts: 5,721
    Are you going to be moving your furniture sans alcohol...... :p
  • BlueFox
    Oh yes, but then the move needs to be evaluated with heightened senses for music. :)
    Seriously though, I have found that the sound is best after the amps have been on about 8 hours, and the night air has settled down. Usually this is around 11PM and later, and that occurs for me on Friday and Saturday night.
