Blue HTC One - M7 32 gig
EndersShadow
EndersShadow Posts: 17,596
edited January 2015 in For Sale (FS) Classifieds
For sale is my 32 gig HTC One in Blue for use with the Verizon network.
Its in decent condition with few scratches on the back of the unit from use as I never found a case I liked for it. I believe I have (but need to check) the original box, if so it will ship in it. It had a Zagg screen protector on it which I just removed as the corners on the protector had lost their adhesion and were collecting dust. As such the screen is in flawless condition.
I know I have at least a USB cord that should work with it and possibly a charger. Will look when I get home.
I will get pictures posted of the actual unit later tonight. Below is just a stock image from Google to show you what it looks like.
I've been around the block and done enough transactions here so you know I'm gonna package and ship it right.
Asking 135 shipped, insured with signature required (CONUS ONLY). Payment via PayPal gift. Any questions ask via PM.
Spec's here
Size 137.4 x 68.2 x 9.3mm
Weight 143g
Display 4.7 inch, Full HD 1080p, 468 PPI
CPU Speed Qualcomm® Snapdragon™ 600, quad-core, 1.7GHz
Platform Android Android™ with HTC Sense™ HTC BlinkFeed™
SIM Card Type micro SIM
Memory1
Total storage : 32GB/64GB, available capacity varies
RAM : 2 GB DDR2
GPS Internal GPS antenna + GLONASS, Digital compass, Sensors
Gyro sensor
Accelerometer
Proximity sensor
Ambient light sensor
Connectivity
3.5 mm stereo audio jack
NFC
Compliant with Bluetooth 4.0
Bluetooth 4.0 with aptX™ enabled
Wi-Fi®: IEEE 802.11 a/ac/b/g/n
DLNA® for wirelessly streaming media from the phone to a compatible TV or computer
HTC Connect
Support consumer infrared remote control
micro-USB 2.0 (5-pin) port with mobile high-definition video link (MHL) for USB or HDMI connection (Special cable required for HDMI connection.)
Sound Enhancement
HTC BoomSound™
Dual frontal stereo speakers with built-in amplifiers
Studio-quality sound with Beats Audio™
Sense Voice
Camera
HTC UltraPixel Camera
BSI sensor, Pixel size 2.0 µm, Sensor size 1/3'
Dedicated HTC ImageChip 2
F2.0 aperture and 28 mm lens
Smart Flash: Five levels of flash automatically set by distance to subject
Optical Image Stabilization (OIS)
Front Camera: 2.1 MP, 880 wide angle lens with HDR capability
1080p Full HD video recording with HDR Video
HTC Zoe™ with Sequence Shot, Always Smile and Object Removal
Gallery with Video Highlights and HTC Share
Continuous shooting and VideoPic
Slow motion video recording with variable speed playback
Multimedia
Audio supported formats:
Playback: .aac, .amr, .ogg, .m4a, .mid, .mp3, .wav, .wma (Windows Media Audio 9)
Recording: .amr
Video supported formats:
Playback: .3gp, .3g2, .mp4, .wmv (Windows Media Video 9), .avi (MP4 ASP and MP3)
Recording: .mp4
Battery3
Embedded rechargeable Li-polymer battery
Capacity : 2300 mAh
Talk time:
Up to 18 hours for 3G
Standby time:
Up to 500 hours for 3G
AC Adapter
Voltage range/frequency: 100 ~ 240 V AC, 50/60 Hz
DC output: 5 V and 1 A
Available storage is less due to phone software.
Network bands in regions may be different, depending on the mobile operator and your location. 4G LTE only available in select countries. Upload and download speeds also depend on the mobile operator.
Battery times (talk time, standby time, and more) are subject to network and phone usage.
A Standby time specification ("specification") is an industry standard that is only intended to allow comparison of different mobile devices under the same circumstances. Power consumption in a standby state is strongly dependent on factors including but not limited to network, settings, location, movement, signal strength and cell traffic . Comparisons of different mobile devices using such a specification can therefore only be done in a controlled laboratory environment . When using any mobile device in real life circumstances for which the mobile device is intended, the standby time could be considerably lower and will be strongly dependent on the factors as mentioned above.
Note: Specifications are subject to change without prior notice.
*4G LTE only available in select countries. Color selection may vary based on availability.
*Zero Gap refers to the ground breaking technology used to create a seamless and smooth metal back integrating multiple antennas without interference from each other.
  • seabeerob213
    seabeerob213 Posts: 1,843
    Interested
    edited January 2015
    Pics below. I should note I took pictures of all scratches on the phone, many of which are hard to see or with a case would be invisible.
    The reflection on the screen shows how clean the front is.
    Once it's charged I will post some more.
    I am having trouble tracking down the factory box and accessories but will look in my shed (outside) tonight.
    If earbuds are a deal breaker I can probably find a unused pair to throw in the box
    It's already been factory reset.
  • seabeerob213
    Sim card? Or network enabled?
    edited January 2015
    A couple reviews that should be able to answer any questions better than I can (I'm somewhat phone dumb) about this this phone can be found here:
    Engadget
    Anandtech
    IIRC this was @AsSiMiLaTeD‌'s favorite Android phone at one point (still may be I forget)
    It has a SIM card slot on the left side.
    Couple more pics attached
  • Excellent phone. I have the new HTC one m8 and I wouldn't trade it for a skint monkey. The HTC Connect works great, and the build quality of these things is superb.
  • rooftop59
    rooftop59 Posts: 8,121
    From what I can tell this will only pull LTE on the verizon network in the US. Not sure about abroad. I would think seriously about it but I am stuck in a contract with AT&T.
    GLWS!
    Game Room 5.1.4:
    Bedroom 2.1
    rooftop59 wrote: »
    GLWS!
    Thanks Paul. I liked it but we switched plans and I got an iPhone because my car (while new) only had a factory 30 pin connector and so I can control my iPhone and music through it using the wheel controls which made the Android phones not as good.
    Any NO the car didnt have bluetooth audio, JUST handsfree. So I switched to the iPhone so I wouldn't be fumbling with my phone in the car while driving with my lil one and whatnot.
    Otherwise I likely woulda kept it.
    Anyway, Bump
    Sold to Rob, shipped out today via USPS Priority.
  • seabeerob213
    Thanks ender
