rti a9 what amp?
I guys. I'm New in this forum and i will be very pleased to have your advice in my future choice to boost my front speakers rti a9. My actual system is:
Receiver - Onkyo TX-NR3007
Subwoofer - Rel Q200
Front - rti a9
center - csi a4
surround - vintage philips speakers
I am satisfied with this setup for HT, even knowing that rti a9s would perform much better with a dedicated amp. With my receiver i think that my rti's boosts good low ends. I even switch off the sub when listening to music in stereo. My only complains are the high ends when listening to music. Beside the amp i am thinking to upgrade my speaker cables, but this is another topic. So back to the amps, I want that every Euro i will spent (yes im from europe/portugal) return a good value for the money. Having this said i am thinking to buy an Emotiva amp. I know that there are some against opinions but, these are the only ones that I can afford. Other ones are just very expensives for my wallet. Im thinking in the XPA-2 (2*300 Watts). My doubt is between this one, and the XPR-2 (2*600 Watts). The XPR-2 wouldn't be too much watts to the rti's a9? Could you give me some advice on this? Please.
Best Answers
  • polkfarmboy
    polkfarmboy Posts: 5,703
    Answer ✓
    Your not going to need 600 watt for a pair of rti. A good high current lower watt amp will sound more meaty than a high watt emo.
    There are many many options and I think if you give us a price range we can get you some better recommendations.
  • Bad1550
    Bad1550 Posts: 10
    Answer ✓
    Recently was considering similar options to drive my LSIM 707s
    I went with the Parasound 2250v2 and could not be happier
    This was my first amp purchase
Answers
  • PauloMateus
    Thank you for your quick answers. So, for what I understand, its better to stay as I am, instead wasting money buying an emo amp. I have done a quick search and found these ones from Parasound that Could fit my needs, the A21 (Halo line), and the 2250 v.2 (NewClassic line). I think the second one is more affordable. Do you think the second one it will be a good choice? Or the A21 will worth the extra money? Other question, just to kill my curiosity with the emo xpr-2 (2*600 watts). Are the Rti's a9 able to deal with 600 watts per channel from The XPR-2?
  • PauloMateus
    My friends. I don't think my wife would allow me to spent a lot of money in one of those Parasound amps. LOL (sniff). Given this, here are my questions:
    1. Just for the case I Could convince her, do you think the Parasound 2250 model will be a good choice?
    2. Are the RTI'S a9 able to andle with 600 watts per channel from The XPR-2?
    3. If my only choice are the Emo, do you think its better to stay with my system as is? Or its better to get the XPA-2?
  • PauloMateus
    Given your enlightning answers (not joking), my conclusion is to buy a Parasound as soon as I could convince my wife how awsome it is, and forget the Emotiva amps. After that, upgrade the front speaker cables. And thats all folks. Thank you all for your atention.
  • PauloMateus
    Hello Bad1550. Thank you for your feedback. My intentions are to get a better experience when listening to music, but Im not completely unhappy with my system as is. And i can't stop thinking If it will be so much better buying a 2000 euros amp(europe prices) and more or less 500 euros for the New speaker cables. Probably it will be better, but it worths 2500 Euros?
  • polkfarmboy
    Paulo I tell my wife when I buy something' cannot put a price tag on something thats going to improve the quality of everyday life'.
  • PauloMateus
    Polkfarmboy even I, have my doubts. But I asked for prices from local distributors (Portugal and Spain) and im waiting for them. Lets see whats will going on. I'll keep you up to date with the developments and my final decision, that will be one of two: stay as I am; or get the 2250
  • PauloMateus
    ZLTFUL it seems you have a diferent opinion about the XPR line. Why do you think its better the 2250 than the XPR-2?
  • PauloMateus
    Ok ZLTFUL. I only asked because you adviced me to stick with the Parasound, wich is somehow a strange advice since you never heard one, and you have a good opinion of the XPR Line.
    Actually we'd pick the Parasound for it's sound quality over the Emo, especially with the RTI speakers your pairing it with.
  • PauloMateus
    Thanks ZLTFUL I'd Suspect that was the reason, apreciate your confirmation.
  • PauloMateus
    Ok Tony understood. Thank you for your time.
  • polk500
    polk500 Posts: 1,171
    Hello Paulo,
    As a Rti A9 owner myself running a Parasound 1500a. I have to say it sounds pretty sweet. Now I also own the Rti A7 and when I first got them I was using a pro amp cerwin vega CV 900 pushed the same watts but sounded like Cr@p.
    Cheers
    Roger
  • PauloMateus
    Hi polk500. The main objective is to get a better experience while listening to music. This requires a good quality class a/b amplification. Having this in mind, the feedback I've got from this forum is that the Parasound amps are the perfect match for the rti's a9. My wallet is limited and I can only dream with the 2250, which is a very good one and will fit the purpose. No im waiting for some prices from local retailers. Lets see what I can get. If anyone think that has some think more to say I'll apreciate a lot. Thank you all.
