Turntable tracking concern
Easy Runnin
in Electronics
So I've been spinning some vinyl and lately when I manually lower the tone arm to the record I notice what seems to be a magnetic force field pulling the needle into the record. I have a Technics SL-D3 turntable and I have an anti static mat on top of the rubber mat on my platter. I usually clean the record with either an original discwasher and/or an audioquest anti static record cleaner. I figure this must be significantly increasing the tracking force. What's going on? Does anybody else ever notice this? What can be done about? What do you say? Thanks
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
Hello,
When you say "pulling the needle into the record" do you mean inward towards the center of the record or downward towards the surface of the record?
Regards, Ken -
downward toward the surface.HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
BR - Yamaha CR800/Polk monitor 5 -
Given the time of year, and assuming that you're in the Northern hemisphere :- ) the problem sure sounds like static electricity to me.
Time for an anti-static gun and a wrist grounding mat or wrist thingy
http://www.newark.com/3m/fgc151m/ground-cord/dp/39M5829?mckv=smKJ9vS8U|pcrid|57087225141|plid|&CMP=KNC-GUSA-GEN-SHOPPING-3M
What tracking force is recommended by the cartridge company?
I've always started at the recommended and backed off from there FWTW.Kenneth Swauger wrote: »What tracking force is recommended by the cartridge company?
The cart is an AT120e. tracking force 1.0 - 1.8. I have it set at 1.4.
I bought this table when it was new and I never noticed this before.HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
weak cantilever perhaps?
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Is your turntable isolated from other components and/or electrical devices? Is it sitting on top of another component or in a rack system?Living Room
Parasound Model 2250v2 amplifier
Parasound P5 preamp
Turntable 1 - Technics SL-1210Mk2 turntable with Shure V-15 Type III cartridge
Turntable 2 - Dual 1229 turntable, Dual AS-12 45 RPM stacker, Shure V-15 Type III cartridge
Schiit Mani Phono Preamp for Turntable 2
Oppo UDP-205 CD/SACD USB and FLAC duties
Technics RS-1500US reel to reel
Polk SDA SRS (2nd Gen) fully modded
