SDA1C with Parasound Halo A21?
I am thinking of upgrading the amplifier that I am using for my SDA1Cs. I am currently using a Yamaha AVR 100 WPC RMS and am looking to use these in a dedicated 2 channel system. I am thinking of the Parasound Halo A21 and was wondering if anyone else had had experiences with this amplifier and any of the large SDA speakers. Any feedback would be appreciated. Thank you,
  • Mikey081057
    Mikey081057 Posts: 7,127
    I have a21 with my modded SDA SRS 2.3's. I am also using the Parasound P5 pre and the everything about it is a great match. The a21 will give you all the power you would ever need.
    Garage | Polk Monitor 5B's
  • bem
    bem Posts: 103
    I also have some SDA SRS 2.3s and I am considering a A21 also. Is the A21 a common ground amp? In other words I don't have to do anything unusual with the outputs of the A21 and the wiring to the 2.3s.?
    SDA SRS 2.3 (non TL) with VR3 mods/RD0194 tweeters/hurricane nuts/Dynamit etc, Simaudio 390 Preamp/DAC, Parasound JC5, SVS (2) SVS SB-3000 Subs, Rega Planar P3 with Exact 2 cartridge, Niagara 1200 Monsoon power cable, Marantz CD5005 player.
    F1nut Posts: 52,007
    There's nothing unusual about using the AI-1 or Dreadnought with your SDA's. In fact, you should use it regradless of the amp as it improves the sound.
  • tratliff
    tratliff Posts: 1,811
    I used an A21 with my SDA SRS for about 2 years. Perfect combination.
  • dpowell
    dpowell Posts: 3,081
    I used a Halo A51 with my 2.3TL's and have since upgraded to a Sunfire Signature Cinema Grande 400 after hearing them side by side. It runs much cooler and has a slight edge over the Halos IMO.
