Height (prescence) channel placement help!
Hey everyone. I need advice on the best placement for my front height or prescence channel. I just added a DENON AVR-X2100W, allowing me a 7.1 setup. Since my seating position is right on the back wall of my theater room, I will not be able to add the extra back surround channel. So I would like to add the front height channel. My focal wall is approx. 15' long (ceiling is at 7'), and my TSI 300's (front channel) are approx. 3.5 ft. off center (7 ft. apart). Where is the best place for the front height channel? I just recently changed my rear channel from my POLK OWM 3's to the OWM 5's, so I can use my OWM 3's for the front height. Or would the OWM 5's be better in that position and the OWM 3's on the back wall? Also, I'd like to set them on shelves, so I wouldn't really be able to angle them up or down. Not looking for perfection here, just great surround. What's the best set-up? I need your input! Thanks.
Yamaha manual says 5.9' from the floor and 1.6' to 3.3' to the outside of the mains.
