Interconnect cable for turntable
muncybob
I'm slowly getting my 2 channel system completed. Next step will probably be the cable from tt to pre. I think I read somewhere that it is desirable to have a very well shielded cable for this or will most any decent quality cable do?
Yep, my name really is Bob.
I've been reading up on this also - it seems shielding is important as well as keeping the capacitance of the cable as low as possible, and the length short. Does your table have detachable cables? Mine are hard wired in which makes things a bit more involved. My first budget minded choice as of now would be the blue jeans LC-1 but they didn't recommend using that for soldered on connections.2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
I use the LC-1's for my tt and I like them just fine. I am sure you can do better, however, for a bit more $.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
Did you solder yours direct?jeremymarcinko wrote: »I use the LC-1's for my tt and I like them just fine. I am sure you can do better, however, for a bit more $.
2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio -
No. My tt has a Rca Jack not soldered on leads. I would suggest removing the leads and soldering a Jack in its place, so you can use any cable you choose to.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
ambiophonics wrote: »I've been reading up on this also - it seems shielding is important as well as keeping the capacitance of the cable as low as possible, and the length short. Does your table have detachable cables? Mine are hard wired in which makes things a bit more involved. My first budget minded choice as of now would be the blue jeans LC-1 but they didn't recommend using that for soldered on connections.
I still use coax IC's for turntables and prefer stranded center conductor for flexibility. Consider getting some replacement ends for your turntable cables. I installed these Vampire coax RCA's on a Yamaha YP-D10 I had.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
For the guys that love to go overboard and have the coin to spend ,all power to ya. Me I have what came w/ my JVC-QL-A200 semi auto w/ fixed RCAs and not replaceable w/ a Grado FT+1 cart. It sounds great w/ running through the NAD1020a pre and my sets of spkrs. I think grounding is way more important.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
My Denon DP-1200 has rca jacks...thanks to member voltz, I'll be receiving his old Pro-ject cable. Since it came with his tt I am assuming it's properly shielded. For grounding I plan to run an insulated solid copper wire? Man, it's been a long time since I spun me some vinyl...looking forward to it! Need to save up some coin to have the old Shur cart retipped, in the meantime I'll be choosing some albums in decent shape to mannualy clean for the audition.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Hey Bob
Cables are on the way, they are actually the ones they sell aftermarket and not the one they give away, so I think you will like them
cool, thanks again!Yep, my name really is Bob.
Timely thread. I was just thinking about replacing the cables on my old Pioneer PL-530. They are hard wired and haven't decided if I'll install jacks or just hard wire new cables.
StanStan
Main 2ch:
HT:
Other stuff:
After trying many cables I found that the blue jean cable LC-1 is the best from TT to phono and use a MIT AVT-1 from phono to PRE-amp. The BJC cable has one of the lowest capacitance I have measured from tonearm wire to RCA end. I'm sure moving up the line to a higher end MIT RCA going to the main Pre-Amp would be better but this is what I settled on. I ordered a foot and a half cable to minimize capacitance. I tried tonearm cables from Kimber and nordost and sent them both back they lost to a cheap 30.00 cable. Also note it had the best shielding out of all the ones I tested. The MIT sounds best IMO I did try a companion BJC LC-1 but it couldn't best audioquest King Cobra or Kimber Hero, Nordost Purple flare, or the winner The MIT AVT-1.
So not to dredge up an old thread - but I had been considering using the Blue Jeans Cable LC-1 for my turntable to phono stage connection for a while now based on the low capacitance, and frankly, the fact that I wasn't that pleased with the Signal Cable Analog 2 IC I was using recently in that spot. Sounded a bit veiled and not very lively I guess.
Long story short, I ordered a 3' pair of BJC LC1s last week and installed them between the Dual 1229 and my Vincent, (then kept SC Analog 2's from the Pho8 to the preamp) and voila! The veil has been lifted! I'm immediately noticing a brighter presentation, and the (admittedly very slight) muddiness is gone - exactly what the Dr. ordered!
Cables DO make a difference.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
I too believe that the low capacitance of the lc1 makes it a good choice for a turntable ic. I have purchased several of these cables and use them exclusively in my system. The BJC lc1's are certainly a great value are a good match for my very modest gear.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
Its a bit pricey.... but I've heard good things about these...
http://www.douglasconnection.com/Douglas-Connection-Alpha-Turntable-Interconnect-cables-DCATTIC.htm
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
^^ I'm sure that's a great cable ^^ very nice indeed! I would love to hear/compare - but as you say - about 7 times the cost of the BJC (plus the Dual also doesn't require a ground wire). I have no doubt cables like this make a huge difference - but for perspective that's about what I spent on all my Signal Cable for 2CH combined! (through the FM here admittedly)VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
Yeah, but I'm sure doug could work with ya on the cost. IIRC the "Alpha" wire is more expensive, so he could likely use a less expensive wire to lower the cost... Maybe the same for the connectors he uses....
And Polk members get a discount too
Doug also got in some new connectors = KLEI pure harmony RCA plugs that combine with that Alpha wire would be a super sweet TT cable , I want to try it someday
Man, I wish my stylus would get here already..it's like waiting for Xmas to arrive when I was a kid. Looking forward to trying out some interconnects then.Yep, my name really is Bob.
Working on that as we speak. Doing some testing on them now. Trying both the copper harmony and silver harmony to see how they sound.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
WTG Doug!
thanks looking forward to your thoughts!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
