New Parasound 2250 v2 Amp - Hum
Just picked up a Parasound 2250 v2 amp to drive my Polk LSIM 707s. I have it connected to the Onkto TX-NR838 preout and my Cable TV
I am getting hum and do not know what to do as I am a newbie to amps. I have the Center, 2 surrounds and 2 heights connected to the Onkyo.
Any help to finally hear the 707s shine and without hum would be greatly appreciated. Ive attached a pic of Parasound Amp and Onkyo connection
Thanks,
    Could be a ground loop....but your cables seem on the entry level side too so you may want to consider better quality cables. Do you have the amp in bridged mode ? If so, take it off.
    Get yourself a 2 buck cheater plug at any hardware store. A 3 prong to 2 prong adapter and see if that helps with the hum.
  • Bad1550
    Bad1550 Posts: 10
    I do not have the bridge mode enabled
    I will pickup an adapter prong and hopefully that will solve the hum
  • Bad1550
    Bad1550 Posts: 10
    Picked up this Ground Loop Isolator from RadioShack and resolved the problem
    http://www.radioshack.com/ground-loop-isolator/2700054.html#q=Ground+loop&start=1
  • I wouldn't want that in my signal chain. Take Tony's advice get the two/three prong adapter.
  • Bad1550
    Bad1550 Posts: 10
    Just replaced the isolator with the two/three prong adapter and it works great.
    Will return the isolator.
    Thanks again!
    F1nut Posts: 52,151
    edited January 2015
    The ground issue is with your cable service. Tell them their equipment needs a proper ground. The cheater plug should be a temporary fix only.
    You also need a serious speaker cable upgrade.
    Cable companies are notorious for bad grounding and cheap equipment. You can go to any Home depot and buy a copper rod to hammer in the ground near where your service comes in the building. Then just run a wire to a clamp on the rod and to a signal splitter if you have one installed or directly to the box.
    Cheap cables as Jessie suggests too can also be part of a ground loop problem as well as cheap construction grade outlets. The very least install some hospital grade wall outlets for your audio....also available at any Home Depot.
  • Bad1550
    Bad1550 Posts: 10
    I appreciate all of your help!
    Bob
  • steveinaz
    steveinaz Posts: 19,546
    Another "work-around" (if available) is to go toslink from your cable box to your DAC.
  • skrol
    skrol Posts: 3,480
    A bit of an old post but I recently had a hum issue when I had my HCA-1000A on the bench. It was plugged into a separate outlet than my preamp and I had a long, cheap interconnect. Connecting them to the same outlet solved the hum.
    Stan
    Main 2ch:
    HT:
    Other stuff:
