Akai GX-4000D
Just had this delivered. This one does not appear to be covered in smoke residue. Scratches not to bad, side panels have a few bumps and bruises.
All items/lights/meters function although not much to this little guy and don't really like having to remove the capstan sleeve to change the tape speed. Likes my 280D SS better but will give this one a cleaning and then a quick full run.
    mhardy6647 Posts: 35,259
    edited January 2015
    One those passed through here some years back -- it was, AFAIK, the last version (cosmetically updated) of AKAI's single-motor entry level deck -- which they made and sold (initially under the name of Roberts in the US) for a long time.
    16023680997_27e6833213_b.jpgDSCN5751 by mhardy6647, on Flickr
    15589646513_ecf70609cd_b.jpgDSCN5743 by mhardy6647, on Flickr
    Not a bad deck (and, yes, as you can see, this one was a beater), but as you've already noted, not in the same league as the better AKAIs.
    Here's a 1968 version of the AKAI (still sold as Roberts in the US) -- in those days, AKAI was using a crossfield head design (as did Tandberg).
    source: http://www.alliedcatalogs.com/html/1968-270/h124.html
    Post edited by mhardy6647 on
  • oldrocker
    oldrocker Posts: 2,590
    It seems the right input RCA connector is a bit loose. Not always allowing a signal out unless its "wiggled" around. Took it back apart and yes it's a tad lose. Should be a simple solder job. Causing a slight ground issue. Go figure, this one's actually pretty clean. Neat catalog source. THANKS.
