HELP, receiver good for lsi system...
vinh
I have lsi9 & psw650...2 ch.(Onkyo Intrega).....need a good receiver $800-1k 6.1ch. up...call Onkyo & HK & the tech. not recomend any of their system for 4ohms. Polk Audio Lsi.....
Possible I may start w/ new system RTI...if it cost to much.
Please...help...thanks
System #1 2 ch.
Lsi 9 Main(bi-wire)
Psw650 Sub
Future HT plus above
Lsc Center($500)
Lsi7 Surround($700)
Total $2.2k, but I loose 2ch. system for music
System #2 HT 6.1/7.1
Onkyo 601/701($500-$700)
RTI 150 Main($800)
Psw650 Sub
Center($300)
Rti 38 Surround
Total 2k or less
System #1 2 ch.
Lsi 9 Main(bi-wire)
Psw650 Sub
Lsc Center($500)
Lsi7 Surround($700)
RTI 150 Main($800)
Psw650 Sub
Center($300)
Rti 38 Surround
Total 2k or less
Post edited by Ryan_Polk on
If you have a receiver currently that has preouts for a seperate amp all you need is an amp that can handle a 4ohm load. I'm using an 0utlaw 7100 with my Lsi's and it performs beautifully.
I tried many many receivers in my search, I ended up with the Yamaha RX-V2400. I can't say enough good things about it. It can be had from a dealer for about a grand. If you want to save a little, get the RX-V1400. It has many of the same features, and a smidgen less power.
Here is the thread that led me to my purchase....
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=15519&perpage=30&pagenumber=1
Here is a link to Audioholics review of the RX-V2400
http://www.audioholics.com/productreviews/avhardware/YamahaRXV-2400Receiver-p1.htmlGo BIG or go home! -
I would keep your LSi 2 channel system and go with another RTi system for the HT. On your budget you can't afford anything good enough to drive the LSi's, and IMO RTi's do a great job for HT.
on another note, many people will suggest that an onkyo receiver will not have the power to drive the RTi150's to your satisfaction, so perhaps you will want to check out the RTi70's.
