Sony BDP-S570
Easy Runnin
Easy Runnin Posts: 501
edited December 2014 in Electronics
i know it's a little dated but I can pick it up pretty cheap. I was looking to replace an older JVC DVD player in a camper and I thought this would do the trick. Turns out it also plays sacd. I have no experience in this area and was wondering if I should replace the Panasonic DMP-65 in my main system and move the Panasonic to the camper. What do you think?
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
  • Thorton
    Thorton Posts: 1,324
    I picked up a used 770 on ebay for use with my rear projection tv (no hdmi) + amazon prime download. I've had it for about 6 months and it works great. Picture and sound quality is very good. This is the higher model but I believe they were introduced around the same year and probably have alot of the same components.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • "Id rather have a good CD player than a mediocre to bad sacd player."
    Good point, but it won't be my main CD player. Fortunately or unfortunately for me I haven't really heard a good or bad CD player. All the ones I’ve had sound pretty much the same, although I’ve never done any A/B comparisons. My current player in my 2-channel setup is an Integra CDC-3.4.
    I’m picking it up today and I’m trying to figure out the best way to use it. So I guess your impression is it’s a decent bpd but a bad sacd player. That’s what I was figuring but I don’t even own a sacd that I can listen to.
  • Thorton
    DSkip wrote: »
    Is rather have a good CD player than a mediocre to bad sacd player. I had a Sony es player that was essentially the 790 and its sq was bad. Real bad. I still almost kept one though since I needed a decent bdp and that did everything I needed it to for movies. Pure music playback is not their strength though.
    I'm glad Dskip commented. I didn't want to mislead you. I figured this was to replace your video DVD player for movies with Blu-ray. I use mine only for movies. Music, for me, is all flac streaming. My CD player is in storage.
    DAC: Bricasti M1SE
  • mrloren
    mrloren Posts: 2,473
    the BDP-S570 is a very good BD player. I have the 480 and 580 in my house and like them both for movies. For music I still use my 3100ES DVD/CD/SACD player which is awesome.
