In wall speakers/ surround any help please????
Hi all, I am looking at buying in wall speakers / surround sound setup?, looking at the rt range for budget reasons really, 2x 265 rt one either side of tv, 1x centre 255c rt speaker below tv, and 2x owm5 for rear speakers? Firstly if anyone has any suggestions or advice on this I would very much appreciate it, if you have any first hand experience with nay of the speakers in question? my main question though is I will need to build a false wall for the viewing wall. Does anyone know the minimum depth that I would need to leave in order to install these speakers???? I have seen extendable tv mounts that extend from the wall, so the tv will not be an issue, I just would like to know so I can plan it all and see if I have enough room as the room I am looking at doing it in is relatively small? Thankyou all in advance.
