Balanced Interconnects
I'm looking for a decent pair of XLR to XLR interconnect cables to run from my dac to my amp. The shorter the better, looking in the $50-$100 range. I was about to pull the trigger on some Signal Cable Analog II's for $59 but thought i'd at least see if anyone had anything better laying around. Thanks!
  • PSOVLSK
    PSOVLSK Posts: 5,404
    edited December 2014
    http://forum.polkaudio.com/discussion/165070/xlr-cable-pair-blue-jeans#latest
    Maybe a little long since you mentioned the shorter the better, but thought I'd throw it out there in case you hadn't seen it.
  • B Run
    B Run Posts: 1,888
    I hadn't seen it, yeah i'd really like a .5 or 1 meter pair if possible and i'm not sure if i'm going to find anything that will outperform the signal cable for under $100 but at least wanted to throw it out there. Thanks for the heads up though!
  • headrott
    headrott Posts: 5,496
    They are (I think 2m) I will have to check for certain, but I have some very very good balanced IC's done by Aural Harmony (the Sonnet II). They are comprised of cryoed gold alloy and are extremely smooth, detailed and have an excellent soundstage. I know they are longer than you are looking for, but these are extremely flexable and you won't have a problem getting them to fit, guaranteed. PM me if interested.
    All the cables mentioned so far will pale compare to these.
