1.2 tl interconnect. cable
Anyone know where i can buy a blade / pin interconnect cable for my 1.2 tl? Or even where to buy the ends that connect to the speaker and then i can make my own.
Best Answers
    F1nut Posts: 52,000
    Answer ✓
    You can try eBay, they come up from time to time.
    The ends are not available anywhere.
    A better choice is to replace the socket and make a new cable using Neutrik SpeakOn connectors. Do a search here for examples.
  • allstock
    allstock Posts: 136
    Answer ✓
    You can use a rca connector with the outer tangs cut off, the inner pin fits perfectly into the round sda socket. The flat pin was just to mechanically secure the plug better, and was used in the original al-1 cable to provide the ground.
    Two Channel-SDA SRS 1.2tl's,modded, Cambridge Audio 851w amps(2),Cambridge 851e pre, VPI Scout 1.1 tt, Moon audio phono pre,oppo bd105.
    HT-Denon avr3808ci,Carver a-753x,Panasonic ae4000 projector,120" screen,ps3,wii console w/full rockband,Panamax conditioner,dbx120 subharmonic synthesizer,jvc dvd-a player, Polk RTi12 mains,Polk CSiA6 centre, Energy ES-18xl sub,two custom 10" powered subs, Def Tech bp2x surrounds(4),Paradigm monitors-rear(2)
Answers
