Help Would Be Most Welcome
Hello and hopefully thanks in advance.
So I got a new AVR last evening hooked it up and my remote a Logitech ultimate worked great.
Today spent some time hooking up the rest of my components and for some reason now it won't control the Yamaha 2040 without a direct line of site.
All my components are in a closet and up till today everything worked just fine.
Can't seem to figure it out, when over the setup about five times. It's like the Yamaha decided it doesn't like IR blaster it works only with RF.
So any ideas?
Cheers
Roger
  • polk500
    polk500 Posts: 1,171
    Well couldn't figure out what happened so I when into harmony software setup and deleted the Yamaha installed it again and all's good.
    Should have done it earlier.
    Cheers
    Roger
  • BlueFox
    BlueFox Posts: 15,251
    I never could get a Harmony to control my Pass XP-20. Thankfully, Amazon is very generous with their return policy.
  • polk500
    So what remote did you go with?
  • BlueFox
    Pass. I told the dealer the remote was starting to be erratic, and he had Pass send me a new one. The funny part is after that the first started working correctly. Now I have a spare. :)
    I wish that was how all bad gear issues are resolved.
  • polk500
    Never hurts to have a spare. And sounds like a good dealer service.
    Cheers
    Roger
