Polk Audio Sda Crs+ Problem
Hey guys Im new to this community but happy I found it. I have two vintage pairs of Polks. A pair of Monitor 5 series 2 and the Sda Crs+ one tweeter ones. My question is about the SDAs. I had them set up to my Realistic Sta2100d with a pair of klipsch kf28. Had all four channels running A+B and it sounded amazing. Now all of a sudden the right side tweeter on the sda starts crackling/ popping at higher volume. Tried them by themself same thing. Tried just the klipsch doesn' t do it. Any idea what it could be? The tweeter or crossover? The left side one plays flawlessly. Any help would b greatly appreciated.
  • boston1450
    boston1450 Posts: 7,758
    Switch tweeters around & see if it follows that tweeter. That might be a good starting point
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    F1nut Posts: 51,904
    Don't do that again, that receiver doesn't have the guts to drive 4 speakers at any volume without running into issues, which you have discovered. Besides, you have 2 very different speakers with very different sound signatures, which despite your impression, never sounds good when you get down to it.
    Properly set up and powered, your SDA's will provide a realistic sound stage without the need for an extra set of speakers. How do you have them set up? Do you have the SDA cable?
    Your tweeter problem is either a bad polyswitch (on the crossover) or you cooked the tweeter. Swap the tweeters as boston1450 suggests.
  • boston1450
    edited November 2014
    Kinda had me wondering - at high volumes & running 2 sets of speakers = bad news. Those CRS's are crying :(
    Randy-Maine
    by David WMG
  • That amp is 125 watts a channel of old school power should be enough power? I switched the tweeter and it doesn't follow the tweeter so it must be something inside? How would you change the polyswitch?
  • Also yes I have the sda cable. Have them approximately 12 feet apart facing forward about half foot from the back wall.
  • If it's the same as on the 2Bs it's the blue looking round top resistor on the bottom of the x-over . Desolder and replace w/ Mills 2.5 resistor from PE or any store of your choosing resolder and if that was the problem then it's done. 12 ' on the spred might be a bit to far but I'm not the SDA expert. Do not run multiple sets, I can and I don't.
    F1nut Posts: 51,904
    It's 120wpc not that 5 watts makes much difference here. The issue is the power supply, the D version was stripped of the superior toroidal transformer used in the 2100. Regardless, you can't drive 4 speakers at higher volume levels without running into issues, clipping being the major concern.
    The polyswitch is on the top side of the crossover board, marked S1 on the board. It will be either blue or mustard colored. The part number is RDE050A.
    Since you using a receiver, I strongly suggest that you do not replace the poly with a .5 ohm resistor (the 2.5 ohm suggestion is wrong).
    12 feet apart is too far, 6 to 8 feet is ideal.
  • boston1450
    Wouldnt running 6ohm & 8ohm speakers with a receiver at the same time pose a problem ? I thought i understood you could run 4 same ohm 4channel/quad
    Randy-Maine
    by David WMG
    F1nut Posts: 51,904
    If you were using 4 of those Klipsch speakers it probably wouldn't be much of an issue as their efficiency is likely in the high 90's, so not much power is required to get them to play loud. The CRS+ are rated at 90dB, so a lot more power is required to drive them to high levels.
  • boston1450
    CRS's are 6 ohm arent they ? Those Klipsch are 8 ohm i do believe. Just had me wondering if that could be another issue that may lead to other issues. I realize 120+- wpc is doable for one set of speakers OR 2 sets (4) of efficient speakers
    Randy-Maine
    by David WMG
  • boston1450
    + 1 on distance for best SDA effect..... So what should he use ? Can they be bypassed ?
    Randy-Maine
    by David WMG
    F1nut Posts: 51,904
    Not really a factor, the difference isn't big enough. The efficiency difference matters more in this case.
    New polyswitches.
  • Thanks guys for the answers and help. Don't think I want to play with the crossovers. Any recommendations of anyone in Canada or US to do the upgrade?
  • Schurkey
    Schurkey Posts: 2,122
    VERY, VERY simple. If you can do electrical soldering--or even if you want to learn--this is an excellent project.
    Four solder joints with reasonable access = piece of cake. (TWO solder joints, if you're only going to "fix" the one defective speaker)
    If you insist on subcontracting; ANYONE with soldering experience can do this; including any local TV/radio/stereo repair shop--or any DIY electronics enthusiast.
    F1nut Posts: 51,904
    'BYE, BRUNO!
    LOL
  • nspindel
    nspindel Posts: 5,343
    Agree 100% with Jesse. Replacement of polyswitches with a resistor is only advisable in situations where you have a quality amplifier with loads of headroom, where you risk blowing out your eardrums sooner than you'd make your amp start clipping. With a Realistic receiver, polyswitches should still be utilized. The existing ones should be replaced with new polyswitches not resistors.
  • boston1450
    [/quote] i read that. What size should be used ? And should both be done to match/or replace to factory specs ?ixd6zw09o6y8.jpg
    Randy-Maine
    by David WMG
