Question for you mechanic types....need a gear puller
I need to pull a bearing off a fan and see all sorts on the internet and ebay. While the bearing is fairly small I want something that will also be useful in the future, so I don't want to buy a piece of junk that is limited in use or will break...any suggestions on types or brands? Would like to stay at/under $60 or so.
Yep, my name really is Bob.
    F1nut Posts: 51,696
    There is no one size fits all when it comes to bearing/gear pullers, I have at least 10. Best advice, get the one that fits your needs for this job.
  • ken brydson
    ken brydson Posts: 8,988
    For a 1 off job I'd look at renting one.
  • chumlie
    chumlie Posts: 8,658
    See if you can borrow one from parts store. Some loan tools.
  • gdb
    gdb Posts: 6,012
    So many go the route of buying one at Sears, use it, then return it. (not me) If you've got some drill bits, taps and machine screws, you can make one up out of mild steel a lot of times. Also, sometimes a couple C-clamps or bar clamps can be used for pulling duties. Wear eye protection ! Those things can slip, suddenly and violently on occasion. Beware of the soft, die-cast pot metal used on many fan pulleys it can break very easily. :o
  • Auto parts stores will let you borrow one for a deposit that you will get back when the tool is returned.
  • exalted512
    exalted512 Posts: 10,735
    x4 for getting a parts store loaner.
  • muncybob
    muncybob Posts: 3,235
    A loaner would be cheaper for sure, but I like to have tools on hand that I may need and I can just take 'em out of the tool box. On pullers, if it says they are 3"...does that mean will handle 3" diameter or will reach down 3"?
