Back surrounds for RTIA system, will OWM3 match?
Hi my current system is a 5.1 rtia with a Denon x3000 receiver
Fronts: Rti A5
Center: CSI A6
Sides: FXI A6
I am moving the home theater to a dedicated room 13 wide, 9 tall and 21 long so I was planning to add 2 back surround speakers, they will be wall mounted, my first choice was rti a1 but its king of big for wall mounted and looks kind of silly in the wall. I was wondering if the OWM3 or OWM5 will match my other speakers. Any help is appreciated.
Regards,
Jonathan P.
  • slk55amg
    slk55amg Posts: 305
    See if you can find some FXI 3,s I use them for rear surrounds, exellent, and not so large as to be a problem on the wall.
    Emotiva XPA5, Sony ES 5300,: Lsi 15,s LSIC, Monitor 70,s, ( side surrounds) FXI 3,s, (rear surrounds)Micropro4000, Velodyne DEQ 10, Sony 55inchXBR 930D Sony BDP 790 Bedroom rig SonyES 3200 RTIA1,s CSIA4 FXI3,s polk PSW 10 SONY 34inch XBR960:cool:SONY BDP550
  • jonapv
    Yes, fxi series are not to deep and look nice on the wall but according to THX the back surround should be monopole speakers that why I was looking for rtia1 or owm (only 4 inches deep) but thanks.
  • ken brydson
    ken brydson Posts: 9,105
    You'll be fine...
