MIT Cable Recommendation
Not sure if this belongs here or not....
I have grey MIT T2 interconnects throughout my system; and had T2 (older beige) speaker wire, which just went out on me. Would you recommend I buy a used matching grey set of T2 speaker wire? Or should I jump on one of Joe Abrams' deals on the AVT2? I would love to try out shotguns, but my budget will not allow that at this time.
ChrisIntegrated Amp: Cary SI-300D Processor: Marantz SR7012 Streaming: Bluesound Node 2I 4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
    F1nut Posts: 52,159
    It's always best to post your question once. I answered in your other thread.
  • dagame27
    dagame27 Posts: 599
    Thanks. Is there a way to delete this thread?
  • Sure, a moderator would need to do it. They can merge them too, but there isn't any point in doing that.
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
