MIT Cable Recommendation
dagame27
dagame27 Posts: 599
I have grey MIT T2 interconnects throughout my system; and had T2 (older beige) speaker wire, which just went out on me. Would you recommend I buy a used matching grey set of T2 speaker wire? Or should I jump on one of Joe Abrams' deals on the AVT2? I would love to try out shotguns, but my budget will not allow that at this time.
ChrisIntegrated Amp: Cary SI-300D Processor: Marantz SR7012 Streaming: Bluesound Node 2I 4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
    F1nut Posts: 52,018
    Move up to the AVT2's. You can always call Joe to discuss your cable needs.
  • dagame27
    dagame27 Posts: 599
    Thanks for the recommendation; I bought the AVT2's from Joe
  • Mike Reeter
    Mike Reeter Posts: 4,315
    dagame27 wrote: »
    SOUND choice B)
