RM 2600 repair
kevhed72
Does anyone know how to take apart the cabinet of one of these....there are no visible screws or bolts. Thanks
Hello,
After you remove the speaker's grille cover there are small rubber cups, called "catch-cups" that are where the grille cover's pegs fit into. Use needle nose pliers to remove the catch-cups and there will be screws underneath to remove the front baffle.
Cheers, Ken -
Thank you Ken
