What do i do....
Smithinson
in Speakers
Hey everyone i have a pair of Polkaudio Rti8 towers and they seem to be playing a flat tone... its not the amp or amp settings, apart from turning up the treble to full to get a half decent sound. Which i don't and shouldn't have to do..... So my question is are they blown and fixable? or toast...
Any sound from the tweeters at all??Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
V. is right. Get that ear on it and play some noise hiss tone through it that's above the crossover cutoff. Something around 4-5Khz or higher, listen for the hiss!
Could very well be a blown tweeter.
I would assume either a blown tweeter like mentioned above or something blew in the crossover.
The crossover is easy to pull out from the back by unscrewing the binding post plate and looking for anything burnt or odd.
is it both speakers or just one? -
are the jumpers secure?
