90 Day dust cleaning done.
Finally, got this quarter's cleaning done. The best part is "to me" it sounds better.
I swear the little thing on top of my ball cap was actually "vibrating" a time or to :o
  • oldrocker
    oldrocker Posts: 2,590
    :s Crap, WRONG room to post... Rats!!!
    gudnoyez Posts: 8,174
    What's on the top of your ball cap?
  • oldrocker
    That little metal "thing" on top of all hats. It was a "shaking" a little bit that's for sure.
    Probably had something to with getting my 2250 back in the loop.
    Been just running my 11's on a yamaha 2 channel for some time.
    Decided after "3 hours" of cleaning to put the SDA's back in the lead position <3
  • BlueFox
    BlueFox Posts: 15,250
    3 hours! That's a lot of dust. :)
    I like cleaning my stereo before listening just so that it looks its best while rocking.
  • oldrocker
    I took all the tops off, blew em out, swept the edges. Got seriously confused on the 2250's power cord "I put it behind a speaker" and could not find it for the life or me. My wife walks in and says "what's the matter?
    Then she says is this what your looking for? I said yes Dear:(
    Marantz recievers from that era are all that for sure!
  • oldrocker
    Yes, a 2385 is in my future some day B)
