Very Nice Denon DCM 280 5 disc player with new remote and box
geppy1
Very nice Denon DCM 280 5 disc player with original box/packing ,owners manual and new remote conrtol. I thought I would use this but turns out I do not need it. It is in excellent condition and works perfectly More information below. PM me for pictures Asking $65 Thanks
DESCRIPTION
Denon's DCM-280 is loaded with advanced technology to give you the rich, warm CD sound you crave! A Multilevel Noise Shaping D/A converter fights jitter and helps bring out the subtlest musical details on your CDs. In addition to playing regular CDs, audio CD-Rs and CD-RWs, the DCM-280 also handles MP3 CDs, which can hold up to 10 times as much music as standard discs!
This 5-disc changer is solidly built for smooth, quiet operation, and comes packed with convenience features. The CD tray rotates both clockwise and counter-clockwise for easy loading and unloading of your discs. Three random play modes and 32-track programming help keep your music sounding fresh. And a coaxial digital output lets you hook up an external CD-R recorder to make digital recordings of your favorite discs.
Features
Advanced Multilevel Noise Shaping DAC: The DCM-280 features a Multilevel Noise Shaping DAC. This multi-level modulation powerfully removes the adverse effects of jitter, and because it is built into the output amp, a clean analog output with suppressed high-frequency interference can be directly obtained.
Disc Exchange: You can exchange up to 4 discs while playing a fifth; once the drawer is open, 3 CDs can be changed, then you must use the disc skip button to remove the remaining one.
Variable Headphone and Line Outputs: The output levels are controlled by remote only (controlled using the volume +/- buttons). The line and headphone output levels are affected simultaneously, so the line output level cannot be changed without changing the headphone output level (and vice versa). If the variable line output level is changed while recording a CD from the analog outputs of this unit, the recording levels will be affected.
Music Calendar: The player has a 20-track music calendar.
MP3 Playback: This unit will play MP3 files recorded onto CD-R and CD-RW discs using the ISO 9660 level 1 and level 2 formats. A maximum of 99 folders can be played on the DCM-280. Folders over 8 layers down, however, cannot be played. The maximum number of files is also 512. If there are 513 files, only the first 512 are played. This unit allows you to choose Full Random Play or Disc Sequential Random Play. When Full Random Play is selected, all the tracks on the loaded discs are played in random order. When Disc Sequential Random Play is selected, you can select the CDs to be played in random order. Up to 5 disc can be selected, and the same disc can be selected two or more times. Using Repeat Play, you can repeat the current track, current disc, or all discs.
Program Play: Up to 32 tracks can be programmed and played in any order.
Random Play: This unit allows you to choose Full Random Play, Program Random Play, or Disc Sequential Random Play. When Full Random Play is selected, all the tracks on the loaded discs are played in random order. When Program Random Play is selected, all the programmed tracks are played in random order. When Disc Sequential Random Play is selected, you can select the CDs to be played in random order. Up to 5 disc can be selected, and the same disc can be selected two or more times.
Repeat Play: The DCM-280 allows you to repeat the current track, current disc, or all discs. In addition, you can repeat Program Play and Random Play.
Direct Selection: Using the supplied remote, you can directly access discs and tracks
DESCRIPTION
Features
BUMP
