Parasound HCA-1201A monoblock amplifier
shawn474
Started a project and never got around to it. For sale is a parasound hca-1201a monoblock amplifier. These are very well regarded and thx certified. There are two blemishes on the faceplate that I could not get to show in the pictures but do not affect performance at all and are not noticeable from 5 feet away. Specs are below:
FEATURES
THX Ultra certified by Lucasfilm Ltd.
280 VA power transformer, 20,000 uF filter capacitance
Massive toroid power transformer
Multiple polystyrene film bypass capacitors in power supply
Can be powered with external DC source
Cascode Class A input stages with matched J-FET pairs
Complementary transistors in high voltage driver stage
12 ampere 50 MHz output transistors
Output transistors direct-coupled to speakers without LRC networks
Direct-coupled audio circuits with 0.8 Hz rolloff
High-bias Class A/AB operation
Gold-plated RCA input jacks
Multiple protection circuits
Glass epoxy circuit boards, double-sided for precision
Audiophile-grade AC power cord
SPECIFICATIONS
Continuous Power Output:
150 watts RMS, 20 Hz-20 kHz
8 Ω 240 watts RMS, 20 Hz-20 kHz, 4 Ω
Current Capacity:
36 Amps peak
Slew Rate:
> 130 V/microsecond
Power Bandwidth:
5 Hz-100 kHz, +0/-3 dB at 1 watt
Total Harmonic Distortion:
< 0.03 % at full power
< 0.01 % typical levels
IM Distortion:
< 0.03 %
TIM:
Unmeasureable
Dynamic Headroom:
> 1.5 dB
Input Impedance:
33 k Ω
Input Sensitivity:
1 V for 28.28 V;
THX Reference Level; 1.2 V for full output
S/N Ratio:
> 120 dB full power
> 96 dB THX reference level
Damping Factor:
> 800 at 20 Hz
Dimensions:
6 1/4" wide x 5 1/2" high x 16" deep
Power Requirements:
110 Vac-120 Vac 360 Watts
Net Weight:
12 lb
It will come with a standard power cord. I am asking $100 plus shipping.
FEATURES
SPECIFICATIONS
Current Capacity:
36 Amps peak
Slew Rate:
> 130 V/microsecond
Power Bandwidth:
IM Distortion:
< 0.03 %
TIM:
Unmeasureable
Dynamic Headroom:
> 1.5 dB
Input Impedance:
33 k Ω
Input Sensitivity:
1 V for 28.28 V;
S/N Ratio:
> 120 dB full power
Damping Factor:
> 800 at 20 Hz
Dimensions:
Power Requirements:
Net Weight:
12 lb
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
Front: Polk LsiM703
Rear: LSI fx
SOLDShawn
Front: Polk LsiM703
Rear: LSI fx
