Wood Treatment Question
HI all,
I have a question for Wood treatment. A family member gave this set of 4 patio wood chair. But they seem to need some care. Do I paint, stain or just clean them.
Cheers
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • MrBuhl
    MrBuhl Posts: 2,419
    edited October 2014
    Nice family member!
    That would appear to be a teak chair, use some teak cleaner and a scrub brush and you'll be amazed how bright the wood will be. You'll want to do that no matter what method you decide to use.
    From there, it's up to you, you can use teak oil to preserve the wood, but it requires a reclean/reapplication once or twice a year.
    I've also used Helmsman Spar Urethane, in an effort at a more permanent finish, but honestly, they will still need to be cleaned once a year.
    You can just also let them age to a nice grey like teak does. It's a great and versatile wood, (and it ain't cheap)!
    Congrats!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
    txcoastal1 Posts: 13,519
    Do not urethane.
    More than likely Jesse will chime in, if he doesn't PM him and I'm sure he'll give great advise, he refurbs and repairs antiques. He's helped me on a couple home projects along with many others.
    Along with any other outdoor wood projects they require maintenance.
    They are worth saving, but if you don't want to maintain then restore and flip them.
    Nice hand me down....good luck
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited October 2014
    I used teak patio furniture outside for years.
    It is beautiful, but it requires maintenance -- as above, at least annual cleaning and treatment with teak oil.
    To clean, I used a hand sprayer with a mixture of bleach to kill mold and mildew with house wash (M1, I think is the brand), followed by pressure washing.
    Then treat with teak oil.
    When I moved to New Hampshire, I finally moved the furniture inside to use so that I don't have the annual maintenance work.
    Post edited by Moose68Bash on
    F1nut Posts: 52,005
    Good advice from all. Bottom line, it doesn't matter what you put on them as long as they are outside they will require up keep.
  • Irrenhaus
    Irrenhaus Posts: 1,105
    edited October 2014
    Hi
    Thanks for the advice appreciated.
    For cleaning can I use ZEP deck and fence cleaner.
    Cheers
    Rey
  • When I had teak on my boat I used bronze wool to clean followed by teal oil. There are several new products today but I no longer have teak on the boat. Here is a good link to check out:
    http://www.jamestowndistributors.com/userportal/search.do?freeText=teak oil&resultPref=all&page=GRID&history=
    HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
    Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
    2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
    Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
    BR - Yamaha CR800/Polk monitor 5
