Martin Logan Subwoofer in like new condition
Looking to sell a mint Martin Logan Dynamo Subwoofer.
Includes factory box, packaging, manual, power cord, carpet spikes
Unit looks and sounds great.
Subwoofer can be positioned to fire down or forward
This subwoofer is great for music and home theater.
http://www.martinlogan.com/products/dynamo
Frequency Response - 25--120 Hz ±3dB; Anechoic through LFE effects input
Low Pass Filter Frequency - 30--80 Hz
High Pass Filter Frequency - 70 Hz
Low Frequency Transducer - 10" (25.4cm) high excursion, aluminum element woofer with extended throw drive assembly
Amplifier - 200 watts rms
Impedance - Line level RCA: 20,000 Ohms
LFE RCA: 34,000 Ohms. Compatible with 4, 6, or 8 Ohm rated amplifiers.
Components - Custom wound audio transformer, polypropylene capacitors, air core coils
Audio Controls - Power: Auto/On/Standby
Inputs - RCA line level; RCA LFE; speaker level
Weight - 28.5 lbs. (12.9 kg)
Dimensions (down-firing configuration) - 13.9" × 11.7" × 12.6" (35.3cm × 29.7cm × 32cm)
Dimensions (front-firing configuration) - 13.9" × 11.7" × 12.9" (35.3cm × 29.7cm × 32.8cm)
